does Log Server support Netscaler ?
gornm565
Post by gornm565 »
Does Nagios Log Server support Citrix Netscaler? Can it receive logs from it?
Thank you.
Re: does Log Server support Netscaler ?
I'm not personally familiar with that software, but a quick google search I found this which are some looks like a filters you could add into Log Server and send the data via syslog input
https://gist.github.com/haukurk/95a7dad58ff475fbb987
gornm565
Post by gornm565 »
Where in the Nagios Log Server do I input this config to be able to index the Netscaler syslog output?
cdienger
Post by cdienger »
Inputs and filters can be added under Administration > Global > Global Configuration > Add Inputs / Add Filter.
https://assets.nagios.com/downloads/nag ... ilters.pdf
gornm565
Post by gornm565 »
I am sending syslog from the Netscaler to the Nagios Log Server and NLS is successfully receiving the logs. However, the message part isn't being indexed. I tried adding the Filter using instructions above but I am getting an error: "There was an error in the configuration!" when I try to Verify Configuration. Any ideas on where to go from here?
gornm565
Post by gornm565 »
Here's a typical syslog message:
10.212.7.3 09/18/2017:19:56:27 GMT NYCTXPROD1 0-PPE-0 : default SSLVPN ICAEND_CONNSTAT 348417 0 : Source 244.71.101.34:57682 - Destination 10.222.7.154:2598 - username:domainname abusell:propriet.com - startTime "09/18/2017:19:33:33 GMT" - endTime "09/18/2017:19:56:27 GMT" - Duration 00:22:54 - Total_bytes_send 569291 - Total_bytes_recv 14979972 - Total_compressedbytes_send 0 - Total_compressedbytes_recv 0 - Compression_ratio_send 0.00% - Compression_ratio_recv 0.00% - connectionId 88ade3
How do I index it, so that the username, the source/destination IP address/port and timestamps are searchable?
cdienger
Post by cdienger »
If there's a problem with the config, the verify will usually throw some detailed output usually complaining about missing something it expected. Can you provide a screenshot? I'd like to see this as well as the config which can be gathered by clicking the View button on the Global Configuration screen and selecting All Files Combined.
tacolover101
Post by tacolover101 »
gornm565 wrote:Here's a typical syslog message:
make a grok pattern to parse it. this tool is pretty handy to help verify - https://grokdebug.herokuapp.com/
cdienger
Post by cdienger »
Thanks for the link, tacolover101!
gornm565
Post by gornm565 »
View All Files Combined:
# Logstash Configuration File
# Dynamically created by Nagios Log Server
# DO NOT EDIT THIS FILE. IT WILL BE OVERWRITTEN.
# Created Tue, 19 Sep 2017 18:55:28 -0400
# Global inputs
input {
    syslog {
        type => 'syslog'
        port => 5544
    tcp {
        type => 'eventlog'
        port => 3515
        codec => json {
            charset => 'CP1252'
    tcp {
        type => 'import_raw'
        tags => 'import_raw'
        port => 2056
    tcp {
        type => 'import_json'
        tags => 'import_json'
        port => 2057
        codec => json
    filter {
            grok {
                            break_on_match => true
                            match => [
                                    "message", "<%{POSINT:syslog_pri}> %{DATE_US}:%{TIME} GMT %{SYSLOGHOST:syslog_hostname} %{GREEDYDATA:netscaler_message} : %{DATA} %{IP:source_ip}:%{POSINT:source_port} - %{DATA} %{IP:vserver_ip}:%{POSINT:vserver_port} - %{DATA} %{IP:nat_ip}:%{POSINT:nat_port} - %{DATA} %{IP:destination_ip}:%{POSINT:destination_port} - %{DATA} %{DATE_US:DELINK_DATE}:%{TIME:DELINK_TIME} GMT - %{DATA} %{POSINT:total_bytes_sent} - %{DATA} %{POSINT:total_bytes_recv}",
                                    "message", "<%{POSINT:syslog_pri}> %{DATE_US}:%{TIME} GMT %{SYSLOGHOST:syslog_hostname} %{GREEDYDATA:netscaler_message} : %{DATA} %{IP:source_ip}:%{POSINT:source_port} - %{DATA} %{IP:destination_ip}:%{POSINT:destination_port} - %{DATA} %{DATE_US:START_DATE}:%{TIME:START_TIME} GMT - %{DATA} %{DATE_US:END_DATE}:%{TIME:END_TIME} GMT - %{DATA} %{POSINT:total_bytes_sent} - %{DATA} %{POSINT:total_bytes_recv}",
                                    "message", "<%{POSINT:syslog_pri}> %{DATE_US}:%{TIME} GMT %{SYSLOGHOST:syslog_hostname} %{GREEDYDATA:netscaler_message} : %{DATA} %{INT:netscaler_spcbid} - %{DATA} %{IP:clientip} - %{DATA} %{INT:netscaler_client_port} - %{DATA} %{IP:netscaler_vserver_ip} - %{DATA} %{INT:netscaler_vserver_port} %{GREEDYDATA:netscaler_message} - %{DATA} %{WORD:netscaler_session_type}",
                                    "message", "<%{POSINT:syslog_pri}> %{DATE_US}:%{TIME} GMT %{SYSLOGHOST:syslog_hostname} %{GREEDYDATA:netscaler_message}"
# Local inputs
# Global filters
filter {
    if [program] == 'apache_access' {
        grok {
            match => [ 'message', '%{COMBINEDAPACHELOG}']
        date {
            match => [ 'timestamp', 'dd/MMM/yyyy:HH:mm:ss Z', 'MMM dd HH:mm:ss', 'ISO8601' ]
        mutate {
            replace => [ 'type', 'apache_access' ]
             convert => [ 'bytes', 'integer' ]
             convert => [ 'response', 'integer' ]
    if [program] == 'apache_error' {
        grok {
            match => [ 'message', '\[(?<timestamp>%{DAY:day} %{MONTH:month} %{MONTHDAY} %{TIME} %{YEAR})\] \[%{WORD:class}\] \[%{WORD:originator} %{IP:clientip}\] %{GREEDYDATA:errmsg}']
        mutate {
            replace => [ 'type', 'apache_error' ]
# Local filters
# Global outputs
# Local outputs
cdienger wrote:If there's a problem with the config, the verify will usually throw some detailed output usually complaining about missing something it expected. Can you provide a screenshot? I'd like to see this as well as the config which can be gathered by clicking the View button on the Global Configuration screen and selecting All Files Combined.
Reason: Please use [code][/code] tags around long output
