Show Disabled Notifications Hosts and Services
brdr
Post by brdr »
This question is related to the following article:
https://support.nagios.com/forum/viewto ... 16&t=44399
When I run the query to see what hosts have notifications disabled I see a handful. When I go in XI UI I manually enable notifications for the host that have notifications disabled. All is good.
However when I run the query:
echo 'select host_name from tbl_host where notifications_enabled=0\G;' | mysql -uroot -pnagiosxi nagiosql
These hosts that were just enabled still show up in the query as still being disabled....
echo 'select host_name from tbl_host where notifications_enabled=0\G;' | mysql -uroot -pnagiosxi nagiosql (I still get same hosts disabled, any idea why?)
Brdr
Re: Show Disabled Notifications Hosts and Services
This is because what you are querying in the database is the config value. However there is also a runtime value that takes precedence over the config value.
brdr
Post by brdr »
Hi Scott, thanks for the reply.
Is there a way to force runtime to be the config value? Or, another option to see present value after I have renabled the hosts and services that were previously disabled?
brdr wrote:Is there a way to force runtime to be the config value?
no
brdr wrote:Or, another option to see present value after I have renabled the hosts and services that were previously disabled?
You can see the runtime values on the Status Detail Page -> Advanced Tab -> "Service Attributes" or "Host Attributes"
brdr
Post by brdr »
okie. Let me ask the question a different way:
We have 2000+ plus hosts, and 20,000+ services across our prod/non-prod XI instances. Within this domain roughly 80 users. These users schedule downtime, and acknowledge alerts. Occasionally, they will disable notifications for hosts/services; sometimes by design, sometimes by accident.
As a Nagios administrator how can I query Nagios system to find out hosts/services that have notifications disabled?
Thx
The current running status for hosts and services are stored in the nagios database.
The status of the hosts are in the nagios_hoststatus table and services are in the nagios_servicestatus table.
I think the query you have ran before would work but the database and tables would have to be adjusted.
echo 'select host_object_id from nagios_hoststatus where notifications_enabled=0;' | mysql -uroot -pnagiosxi nagios
Then the output of that command would have to be linked to the nagios_hosts table in the nagios database.
brdr
Post by brdr »
That works. As always, thanks tgriep!
Please close.
