API Object modification
eltrasimaco
Post by eltrasimaco »
I want to change the check_period value in a list of services; how can I accomplish this? in the API docs, I only see "add" and "remove" objects, not modify; maybe getting values, deleting,replacing values and writing? any example around for this?
Re: API Object modification
The easiest way to to change multile at the same time is to use the Bulk Host Modification tool
Configure -> Core Config Manager -> Tools -> Bulk Modifications Tool
You will choose " Change a Single Config Option"
eltrasimaco
Thanks, but the aim was trying to learn how can things be done with the API; the question is "how can I change a host/service value by API Means"
eltrasimaco wrote:Thanks, but the aim was trying to learn how can things be done with the API; the question is "how can I change a host/service value by API Means"
Got it. Yes you are correct this isn't available currently, however it is being developed already for a future release. I unfortunately do not have the timing of when this will be available.
eltrasimaco
OK, will wait for that feature then
Thanks!
