Hello Nagios,
I am trying to monitoring NetApp with nagios 4.3.2 and i get this (see attachments).
What could be the issue here ?
Kind regards,
Ahmad
NetApp monitoring
NetApp monitoring
- Knipsel.PNG (5.36 KiB) Viewed 1527 times
Re: NetApp monitoring
Can you share what plugin you are using?
Can you also post the output when you run the command from the Linux command line on the nagios server
Thanks for your reply!
i am using this one (check netapp NG)
https://exchange.nagios.org/directory/P ... NG/details
[root@localhost nagios-4.3.4]# /usr/bin/perl5.16.3 /usr/lib64/nagios/plugins/check-netapp-ng.pl -H $HOSTADDRESS$ -T UPTIME -C public
output: Alarm clock
i think that is a problem with the SNMP community
Best regards,
output: Alarm clock
Best regards,
You will definitely have to have the community string set correctly to get valid output.ANAF wrote:[root@localhost nagios-4.3.4]# /usr/bin/perl5.16.3 /usr/lib64/nagios/plugins/check-netapp-ng.pl -H $HOSTADDRESS$ -T UPTIME -C public
output: Alarm clock
Can you share your command config as well as your service definition for the services that are giving the errored output?
