check_files how to supress the unknow
DrNox
Post by DrNox »
I am using this command found on this link : http://sites.box293.com/nagios/guides/c ... es-folders
check_nrpe -H 192.168.142.1 -t 30 -c check_files -a path='C:\myFolder' pattern=*.* 'critical=count>0' top-syntax='${status}: ${problem_count}/${count} files' 'empty-state=ok'
When i do it on my empty folder ( i want to be sure that he is empty (that's why i want to manage him ^^), i got an Unknow : no file found.
Do you know how to correct it ?
Thanks for you eventually answer :)
French Baguette
Re: check_files how to supress the unknow
What version of NSClient do you have? The site says
NSClient++ 0.4.3.138 onwards
DrNox
Post by DrNox »
Hey,
I am using the 4.3.2 version
French Baguette
DrNox wrote:Hey,
This sounds like your Nagios version. I'm looking for your NSClient version on the Windows machine.
DrNox
Post by DrNox »
.... sry, i failed ^^
I'am using : NSCP-0.5.0.62-x64
French Baguette
I just looked at your command again and I think you are missing a \ in the drive location
Instead of
should be
check_nrpe -H 192.168.142.1 -t 30 -c check_files -a path='C:\\myFolder' pattern=*.* 'critical=count>0' top-syntax='${status}: ${problem_count}/${count} files' 'empty-state=ok'
Last edited by scottwilkerson on Tue Sep 12, 2017 10:08 am, edited 1 time in total.
Reason: edited code
DrNox
Post by DrNox »
Hum, I don't see the difference It's the same code :?
French Baguette
DrNox wrote:Hum, I don't see the difference It's the same code :?
sorry about that, I updated it. it is right after path=
DrNox
Post by DrNox »
HI, thanks for your answer.
I did you change but i got the same error :
French Baguette
More research and it looks like there is a bug in NSClient in several versions, I just found this:
https://forums.nsclient.org/t/check-fil ... tatus/4109
According to one poster they resolved the issue by updating to 0.5.x and changing the order to:
check_nrpe -H 192.168.142.1 -t 30 -c check_files -a path='C:\\myFolder' pattern=*.* 'critical=count>0' 'empty-state=ok' top-syntax='${status}: ${problem_count}/${count} files'
