NRPE check_disk performance data is wrong.
ray.holtz
Post by ray.holtz »
when I run check_disk on the Ubuntu 16.04 being monitored (apt-get fully up to date), I receive:
user@server:/var/log/apache2/sites$ /usr/lib/nagios/plugins/check_disk -w 20% -c 10% -p /dev/mapper/vgpool--logs-lv--logs
DISK OK - free space: /var/log/apache2/sites 21691 MB (99% inode=99%);| /var/log/apache2/sites=169MB;18443;20748;0;23054
and 'df -h' backs that up with:
user@server:/var/log/apache2/sites$ df -h
Filesystem                         Size  Used Avail Use% Mounted on
<snip out irrelevant data>
/dev/mapper/vgpool--logs-lv--logs   23G  170M   22G   1% /var/log/apache2/sites
And nrpe.cfg has this:
command[check_logs]=/usr/lib/nagios/plugins/check_disk -w 20% -c 10% -p /dev/mapper/vgpool--logs-lv--logs
When I run the check on the Nagios server (Ubuntu 12.04) the data being received is all wrong:
user@server2:/etc/nagios3/objects/servers/linux$ /usr/lib/nagios/plugins/check_nrpe -H 10.10.5.21 -c check_logs
DISK CRITICAL - free space: /var/log/apache2/sites 0 MB (0% inode=0%);| /var/log/apache2/sites=17508311532424MB;-2147483648;-2147483648;0;17508311532480
Here are the versions on the Nagios server:
user@server2:/etc/nagios3/objects/servers/linux$ dpkg -l | grep '^ii' | grep nagios
ii  nagios-images                    0.7                               Collection of images and icons for the nagios system
ii  nagios-nrpe-plugin               2.12-5ubuntu1.2                   Nagios Remote Plugin Executor Plugin
ii  nagios-nrpe-server               2.12-5ubuntu1.2                   Nagios Remote Plugin Executor Server
ii  nagios-plugins                   1.4.15-5ubuntu3.2                 Plugins for nagios compatible monitoring systems (metapackage)
ii  nagios-plugins-basic             1.4.15-5ubuntu3.2                 Plugins for nagios compatible monitoring systems
ii  nagios-plugins-extra             1.4.15-5ubuntu3.2                 Plugins for the nagios network monitoring and manegement system.
ii  nagios-plugins-standard          1.4.15-5ubuntu3.2                 Plugins for nagios compatible monitoring systems
ii  nagios-snmp-plugins              1.1.1-7                           SNMP Plugins for nagios
ii  nagios3                          3.2.3-3ubuntu1.1                  A host/service/network monitoring and management system
ii  nagios3-cgi                      3.2.3-3ubuntu1.1                  cgi files for nagios3
ii  nagios3-common                   3.2.3-3ubuntu1.1                  support files for nagios3
ii  nagios3-core                     3.2.3-3ubuntu1.1                  A host/service/network monitoring and management system core files
ROYALCORP\rholtz@rovsubuntu1:/etc/nagios3/objects/servers/linux$
Is it just that the packages on the Nagios server are out of date, or is there an error somewhere? Thanks for the help!
Re: NRPE check_disk performance data is wrong.
does the nagios user have access to the path?
Can you run this from the CLI on the local machine
sudo su nagios -c "/var/log/apache2/sites$ /usr/lib/nagios/plugins/check_disk -w 20% -c 10% -p /dev/mapper/vgpool--logs-lv--logs"
ray.holtz
Post by ray.holtz »
Thanks Scott, that was it partially, the nagios user doesn't have permissions to see that. I'm trying to figure out where/how to give it permissions, but it's not working out right for me. I put the nagios user in the www-data group, and gave that group rights to the /var/log/apache2 directory recursively. but now I get:
user@server:/var/log$ sudo su nagios -c "/var/log/apache2/sites$ /usr/lib/nagios/plugins/check_disk -w 20% -c 10% -p /dev/mapper/vgpool--logs-lv--logs"
bash: /var/log/apache2/sites$: No such file or directory
What can't it find exactly, I'm a little confused.
Thanks!
I'm sorry I copied the command wrong...
Try this
sudo su nagios -c "/usr/lib/nagios/plugins/check_disk -w 20% -c 10% -p /dev/mapper/vgpool--logs-lv--logs"
ray.holtz
Post by ray.holtz »
At first it only worked on the local server, but not on the Nagios server... then I restarted NRPE on the local server and it works great now! Thanks Scott!
ray.holtz wrote:At first it only worked on the local server, but not on the Nagios server... then I restarted NRPE on the local server and it works great now! Thanks Scott!
Oh ya, sorry I forgot to mention restarting nrpe....
Glad it is working!
