How can we monitor special character using check_http
Hi Team,
For below website we want to monitor the keyword "Status":"1". We are using check_http plugin. i have checked and found that able to monitor only Status but not
"Status":"1".
Can you please help on that.
https://retailws.lsapps.net/us/4.1/Back ... user=44208
o/p on google chrome:
{"Status":"1","ProductCode":"185110007","UPC":"052176995710","ShortName":"511 SLIM BLUE FLAME","Size":"33W x 32L","UnitPrice":"$69.50","PromoDesc":"","PromoPrice":"","ErrorCode":"","ErrorDesc":""}
"Status":"1".
Regards,
Sk Abdul Goffar
Nagios Version:Nagios XI 5.4.8
OS:CentOS release 6.5
Sk Abdul Goffar
Re: How can we monitor special character using check_http
The -s argument should work. From:
https://nagios-plugins.org/doc/man/check_http.html
In action:
-s, --string=STRING
String to expect in the content
[root@nagios ~]# /usr/local/nagios/libexec/check_http -H projects.mcapra.com -u '/test.html' -s '"Status":"1"' -v
GET /test.html HTTP/1.1
User-Agent: check_http/v2.2.1.6.g4103.dirty (nagios-plugins 2.2.1)
Connection: close
Host: projects.mcapra.com
Accept: */*
http://projects.mcapra.com:80/test.html is 616 characters
STATUS: HTTP/1.1 200 OK
**** HEADER ****
Date: Tue, 12 Sep 2017 18:09:01 GMT
Content-Type: text/html; charset=UTF-8
Transfer-Encoding: chunked
Connection: close
Set-Cookie: __cfduid=d27f3f6eed699bea853420eab0d6490b71505239740; expires=Wed, 12-Sep-18 18:09:00 GMT; path=/; domain=.mcapra.com; HttpOnly
Last-Modified: Tue, 12 Sep 2017 17:58:46 GMT
Accept-Ranges: bytes
Server: cloudflare-nginx
CF-RAY: 39d4d0bb82fe2597-ORD
**** CONTENT ****
HTTP OK: HTTP/1.1 200 OK - 616 bytes in 0.800 second response time |time=0.799842s;;;0.000000 size=616B;;;0
[root@nagios ~]# /usr/local/nagios/libexec/check_http -H projects.mcapra.com -u '/fail.html' -s '"Status":"1"' -v
GET /fail.html HTTP/1.1
Connection: close
Accept: */*
http://projects.mcapra.com:80/fail.html is 616 characters
**** HEADER ****
Date: Tue, 12 Sep 2017 18:09:08 GMT
Connection: close
Set-Cookie: __cfduid=ddad7d2774279faa1ab997dd0dd36d7971505239747; expires=Wed, 12-Sep-18 18:09:07 GMT; path=/; domain=.mcapra.com; HttpOnly
Last-Modified: Tue, 12 Sep 2017 17:59:35 GMT
CF-RAY: 39d4d0e8b6da5594-ORD
**** CONTENT ****
{"Status":"0","ProductCode":"185110007","UPC":"052176995710","ShortName":"511 SLIM BLUE FLAME","Size":"33W x 32L","UnitPrice":"$69.50","PromoDesc":"","PromoPrice":"","ErrorCode":"","ErrorDesc":""}
HTTP CRITICAL: HTTP/1.1 200 OK - string '"Status":"1"' not found on 'http://projects.mcapra.com:80/fail.html' - 616 bytes in 0.947 second response time |time=0.947252s;;;0.000000 size=616B;;;0
- Former Nagios Staff
Thanks for the assist @mcapra!
Can you please type the command . I am still getting error.
~]$ /usr/local/nagios/libexec/check_http -H retailws.lsapps.net -s '"Status":"1"' -f ok -I 172.26.227.18 -u "/us/4.1/BackOffice_Mobility/GetProductPrice.svc/ProductPrice" -S -p 443 HTTP CRITICAL: HTTP/1.1 200 OK - string '"Status":"1"' not found on 'https://retailws.lsapps.net:443/us/4.1/ ... oductPrice' - 595 bytes in 0.030 second response time |time=0.029794s;;;0.000000 size=595B;;;0
Regards,
Sk Abdul Goffar
Sk Abdul Goffar
Erm, sure:
Can you execute your check command with the -v flag and verify that "Status":"1" is contained in the response body received by check_http? There's a good chance that check_http is hitting something unexpected.
Like so:
It might also be helpful to know which version of check_http you are using:
/usr/local/nagios/libexec/check_http -H projects.mcapra.com -u '/test.html' -s '"Status":"1"' -vLike so:
/usr/local/nagios/libexec/check_http -H retailws.lsapps.net -s '"Status":"1"' -f ok -I 172.26.227.18 -u "/us/4.1/BackOffice_Mobility/GetProductPrice.svc/ProductPrice" -S -p 443 -vCode: Select all
/usr/local/nagios/libexec/check_http -VFormer Nagios employee
We aren't able to test your URL because we don't have access to it. Perhaps you should try testing on a public URL so that we can see if the issue is with your environment.sgoffar wrote:Can you please type the command
Please find below the output:
check_http v2.0.3 (nagios-plugins 2.0.3)
GET /us/4.1/BackOffice_Mobility/GetProductPrice.svc/ProductPrice HTTP/1.1 User-Agent: check_http/v2.0.3 (nagios-plugins 2.0.3) Connection: close Host: retailws.lsapps.net Accept: */* https://172.26.227.18:443/us/4.1/BackOf ... oductPrice is 595 characters STATUS: HTTP/1.1 200 OK **** HEADER **** Cache-Control: private Content-Length: 155 Content-Type: application/json; charset=utf-8 Server: Microsoft-IIS/7.5 Set-Cookie: ASP.NET_SessionId=z1f2sdt54muqjy5naligp2hg; path=/; HttpOnly X-AspNet-Version: 4.0.30319 X-Powered-By: ASP.NET Access-Control-Allow-Origin: * Access-Control-Allow-Headers: Content-Type Access-Control-Allow-Methods: POST,OPTIONS Date: Thu, 14 Sep 2017 10:02:13 GMT Connection: close **** CONTENT **** {"Status":"0","ProductCode":"","UPC":"","ShortName":"","Size":"","UnitPrice":"","PromoDesc":"","PromoPrice":"","ErrorCode":"021","ErrorDesc":"Invalid UPC"} HTTP CRITICAL: HTTP/1.1 200 OK - string '"Status":"1"' not found on 'https://retailws.lsapps.net:443/us/4.1/ ... oductPrice' - 595 bytes in 0.032 second response time |time=0.031760s;;;0.000000 size=595B;;;0
Regards,
Sk Abdul Goffar
Sk Abdul Goffar
I'm ... confused? "Status":"1" is not included in that response body. Therefore, the check is returning critical. This is expected behavior since your check is expecting "Status":"1" but not finding it in the response body.
"Status":"0" Is included in the response body though. I've highlighted it:
sgoffar wrote:Please find below the output:
Please check the attached screen short you will see the below output.
Regards,
Sk Abdul Goffar
Sk Abdul Goffar
The URL included in your screenshot is different from the one you are using in your check_http execution. It seems to include at least one GET variable, UPC.
Please be sure you are accessing the exact URL you wish to monitor when using check_http. Try adding the full URL to your -u argument.
