Monitor FTP server
cdaniels
Monitor FTP server
Post by cdaniels »
I've got two FTP servers, one on a Linux box running vsftp, and a second one running on Windows Server 2016 that has WS_FTP_server 2017.
I am able to monitor the vsftp system fine , the check that reads and writes a file runs fine.
On the WS_FTP server the command fails stating that it cant retrieve a directory listing.
I dont have any problems connecting or transferring to ws_ftp server so I'm a little lost as to what might be the problem. I'm sure its not a credential problem.
TIA
Chris
kyang
Re: Monitor FTP server
Post by kyang »
Hi @cdaniels,
Can you give me a little more information? Do you have any agents installed on your Windows Server that communicate to your Nagios XI?
Are you using the FTP Wizard to set up WS_FTP monitoring?
Can you show me the command output?
