Hello all,
I recompiled nagios with cygwin so now I have a nagios that works in Windows. The problem is I cannot get anything from NSClient or NRPE. I also recompiled the plugins with the command so now I have "check_nt.exe" and "check_nrpe.exe". I installed NSClient++ to my client.
When I run the following commands from the command line everything seems to be working fine.
ls\plugins>check_nrpe.exe -H 10.0.0.73
I (0.3.9.328 2011-08-16) seem to be doing fine...
ls\plugins>check_nt.exe -H 10.0.0.73 -v CLIENTVERSION -p 12489 -s test
NSClient++ 0.3.9.328 2011-08-16
Unfortunately I am starting nagios, nagios is working fine but I cannot get anything from the client. The plugin output is:
plugin_output=(Return code of 127 is out of bounds - plugin may be missing)
In my nagios-stderr.log file it gives the following error:
/plugins/check_nrpe.exe: error while loading shared libraries: ?: cannot open shared object file: No such file or directory
/plugins/check_nt.exe: error while loading shared libraries: ?: cannot open shared object file: No such file or directory
My services.cfg file:
hostgroup_name windows-comps
service_description NSClient++ Version
check_command check_nt!CLIENTVERSION
My commands.cfg file:
# 'check_nrpe' command definition
command_name check_nrpe
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -c $ARG1$
command_name check_nt
command_line $USER1$/check_nt -H $HOSTADDRESS$ -p 12489 -s test -v $ARG1$ $ARG2$
Do you have any idea about what causes this and how I can fix it?
Thanks in advance.
check_nt and check_nrpe give error for shared object file
Re: check_nt and check_nrpe give error for shared object fil
nevermind, I made it. If there is another one who encounters the same problem, here is the solution.
Do not install nagios service with user credentials. I am running the service as Local System Account and now eveything is working.
