Unconfigured Objects - automation
musrmgr
Post by musrmgr »
I have over 10k new devices reporting in for the first time and populating the unconfigured objects section.
Is there anyway to automatically configure anything that is unconfigured?
-Burley
dwasswa
Re: Unconfigured Objects - automation
Post by dwasswa »
Hi @musrmgr,
There are some options that could help you do this:
1. Bulk Host Cloning And Import Wizard
https://www.youtube.com/watch?time_cont ... UTHrvdgjmQ
https://assets.nagios.com/downloads/nag ... 1493223405
2.Automated Host Management
Also, here is a doc for managing unconfigured hosts....https://assets.nagios.com/downloads/nag ... ios%2520XI
Otherwise,you would have to create a custom solution on your side but please try the solutions i provided first and let me know
In addition to what dwasswa said, I would like to point out that we do have an internal feature request (task_id=2231) for adding this functionality. I am not sure when/if this is going to be implemented. For the time being, I would recommend putting together some kind of custom scripting solution, using the REST API. Hope this helps.
