Hi all, I am trying to use nagios check_snmp plugin to monitor the port status of my cisco 6504E switch.
I successfully use the check_snmp to get the port status but nagios didn't change the status to critical even snmp return the status is down.
It still show "SNMP OK". I already updated check_snmp version to 2.2 but is still abnormal function. It seem the -r 1 is not working.
Below is the command i using:
[root@monitor monitoring-plugins-2.2]# /usr/local/nagios/libexec/check_snmp -H XX.XX.XX.XX -C ABC -o IF-MIB::ifName.1 -o ifOperStatus.1 -r 0
SNMP CRITICAL - *Gi1/2/1* down(2) |
[root@monitor monitoring-plugins-2.2]# /usr/local/nagios/libexec/check_snmp -H XX.XX.XX.XX -C ABC -o IF-MIB::ifName.1 -o ifOperStatus.1 -r 1
SNMP OK - Gi1/2/1 down(2) |
[root@monitor monitoring-plugins-2.2]# /usr/local/nagios/libexec/check_snmp -H XX.XX.XX.XX -C ABC -o IF-MIB::ifName.1 -o ifOperStatus.1 -r 2
My Nagios version is 4.1.1. Is there any way to make "-r 1" function normally? Thank you.
nagios check_snmp problem
DiegoAnjos
Re: nagios check_snmp problem
I use the check below and it warns me whenever the port is down:
The -s 'up(1)' is the expected string. Anything different from this and Nagios will understand that this is not OK.
host_name SW01
service_description PORT 47 UPLINK
check_command check_snmp! -C community -o ifOperStatus.47 -m IF-MIB -l OperStatus -s 'up(1)'
kyang
Thanks @DiegoAnjos,
Here's something I found on another forum post that may be related?
https://support.nagios.com/forum/viewto ... =7&t=39059
Tell the check what you expect for an output
so the -r 1 is for status 1 (up) if the status returns something else then 1 it fails
Let us know if DiegoAnjo's post or mine help
./check_snmp -H 10.xxx.xx.xx 1 -o xx -C public -r 1 -l "FW-01-eth1 interface status"Code: Select all
-r, --ereg=
REGEX Return OK state (for that OID) if extended regular expression REGEX matchesLet us know if DiegoAnjo's post or mine help
