Hi Team,
As check_nt is giving physical+page memory. We are using check_nrpe to monitor windows physical memory usage but now we are getting vulnerabilities because of this. Please give some solution as its very critical issue and affecting the business.
VA Scan Vulnerability For NRPE 5666 on Windows Servers
Re: VA Scan Vulnerability For NRPE 5666 on Windows Servers
NSClient (the agent on your Windows machine) is a third-party agent that can communicate with check_nrpe to run active checks. That is the agent giving you the SSL errors. I looked into their documentation and there are only a few SSL parameters you can configure:
https://docs.nsclient.org/reference/cli ... %20options
https://docs.nsclient.org/reference/cli ... ed-ciphers
but that should remedy most of the issues. The one pertaining to a self-signed certificate is obviously not something we can assist with, as you or your team generated that internally.
There is also a good article on NSClient security by the author here - https://www.medin.name/blog/2012/12/02/ ... ntication/
What NSClient version are you running? Some of those options may or may not be available depending on your version.
To be clear, this report is not saying there is a vulnerability in the software, only that the SSL options supported may be weaker than more recent options.
