Linux monitor ElasticSearch
jkinning
Post by jkinning »
I am trying to monitor ElasticSearch process on a RHEL 7.4 server.
 ./check_nrpe -H elasticl1p -t 30 -c check_services -a 'service=elasticsearch'
  service=elasticsearch: 1
Is there a better way to send a notification if this service is not running? I am guessing the 1 represents one instance running. Is there a better plugin or check to monitor this service?
Re: Linux monitor ElasticSearch
Post by mcapra »
I check via the ElasticSearch API. The service could be running while ElasticSearch is totally hung, so I think the API is more reliable. If ElasticSearch is hung, the API will typically also be hung. check_http can tackle this on a basic level.
As a side note, this is probably my favorite place for super specific Nagios plugins and includes ElasticSearch options (even though they're almost all written in Perl :()
https://github.com/HariSekhon/nagios-plugins
cdienger
Post by cdienger »
Thanks for the input mcapra :) I'd add my +1 to your recommendation.
