Nagios Config Not Applied
matson-itops
Post by matson-itops »
1. yesterday I tried to add 2 hosts and ran into errors. See "Capture2"
Logs Errors
eg. "host can not be a child/parent of itself"
I logically figured I needed to delete the node and readd
however this morning, the nodes were just magically there.
2. tried to verify host as added properly under CCM Core Config manager and saw more errors. See "Capture"
CCM Core Config Manager Error
eg quite a few servers with "not applied" status
can we safely remove and just readd the machines?
See the attached screen shots (redacted)
Re: Nagios Config Not Applied
Post by dwhitfield »
What's the output of ipcs -q? I didn't see anything of particular interest in your profile. I will note though that if you upgrade to 5.4.4 or later, the profiles will be more useful.
matson-itops
$ ipcs -q
------ Message Queues --------
key msqid owner perms used-bytes messages
That makes it look like ndo2db isn't running, but I believe I did see a ticket about issue. Did you want to lock this up and work through the ticket?
