is possible to create a user and limit the menus available
for example I want to remove all the MAPS section from home page
and for example remove reports menu on top
is this possible?
thanks in advance
Jorge Arenas
User with limited interface
Re: User with limited interface
This is not possible presently, however, a standard user can only see the item in the maps in which they are a contact for, so if you are trying to limit them from seeing certain servers this is already taken care of.
