We currently have version 5.3.3. the question is if it is ok to updatestraight at 5.4.10 or it should be better to update to a previous version and then at 5.4.10
Thank you
nagios update
Re: nagios update
Yes you can upgrade strait to 5.4.10.nms_system_support wrote:Hello,
Thank you
