configuration verification failed
I have set up nagios xi and I am trying to have it monitor another aws ec2 instance. However, I get an error saying "configuration verification failed" I tried using both public and private ip . Do you guys have another recommendations on how to get nagios to monitor a ec2 instance?
Re: configuration verification failed
What OS is the system on EC2?
Did you install an agent on the system on EC2?
If so which agent? Did you open the port in the EC2 security settings?
it's redhat linux. yes, I installed nrpe on the system and set up the correct ports
I checked configuration snapshot of this error and viewed the command output:
Reading configuration data...
Read main config file okay...
Error: Command name of command line is NULL
Error: Could not register command (config file '/usr/local/nagios/etc/commands.cfg', starting on line 311)
Did you recently add a command and plugin? The error looks like something is missing
Can you post the following file and we can show you what the command name is (on line 311) that will need to be edited to fix the configuration.
this is the text on line 311
command_name check_xi_deface
command_line $USER1$/check_http -H $HOSTADDRE
SS$ -r '$ARG1$' -u '$ARG2$' $ARG3$
That doesn't look right, can you post the whole file?
I don't know how to save the whole file so I just snipped them and zip it
Let's do this because I need to see it in text form
In the WebUI go to Configure -> Core Config Manager -> Commands
Click the "View Config" icon to the right of any command (it looks like a little blue page)
this will open the config in a new window, copy all of that to a text file and attach it.
# Check command configuration file
# Created by: Nagios Core Config Manager 2.6.8
# Date: 2017-09-25 15:08:33
# Version: Nagios 3.x config file
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
command_name check-host-alive
command_line $USER1$/check_icmp -H $HOSTADDRESS$ -w 3000.0,80% -c 5000.0,100% -p 5
command_name check-host-alive-http
command_line $USER1$/check_http -H $HOSTADDRESS$
command_name check-host-alive-tftp
command_line tftp $HOSTNAME$ 69
command_name check_bpi
command_line /usr/bin/php $USER1$/check_bpi.php $ARG1$
command_name check_dhcp
command_line $USER1$/check_dhcp $ARG1$
command_name check_dir
command_line $USER1$/check_dir -d $ARG1$ -w $ARG2$ -c $ARG3$ $ARG4$
command_name check_dns
command_line $USER1$/check_dns -H $HOSTNAME$ $ARG1$
command_name check_dummy
command_line $USER1$/check_dummy $ARG1$ $ARG2$
command_name check_em01_humidity
command_line $USER1$/check_em01.pl --type=hum --hum=$ARG1$,$ARG2$ $HOSTADDRESS$
command_name check_em01_light
command_line $USER1$/check_em01.pl --type=illum --illum=$ARG1$,$ARG2$ $HOSTADDRESS$
command_name check_em01_temp
command_line $USER1$/check_em01.pl --type=temp --temp=$ARG1$,$ARG2$ $HOSTADDRESS$
command_name check_em08_contacts
command_line $USER1$/check_em08 $HOSTADDRESS$ C
command_name check_em08_humidity
command_line $USER1$/check_em08 $HOSTADDRESS$ H $ARG1$ $ARG2$ $ARG3$
command_name check_em08_light
command_line $USER1$/check_em08 $HOSTADDRESS$ I $ARG1$ $ARG2$ $ARG3$
command_name check_em08_rtd
command_line $USER1$/check_em08 $HOSTADDRESS$ R $ARG1$ $ARG2$ $ARG3$
command_name check_em08_temp
command_line $USER1$/check_em08 $HOSTADDRESS$ T $ARG1$ $ARG2$ $ARG3$
command_name check_em08_voltage
command_line $USER1$/check_em08 $HOSTADDRESS$ V $ARG1$ $ARG2$ $ARG3$
command_name check_email_delivery
command_line $USER1$/check_email_delivery $ARG1$
command_name check_esx3_guest
command_line $USER1$/check_esx3.pl -H "$HOSTADDRESS$" -f "$ARG1$" -N "$ARG2$" -l "$ARG3$" $ARG4$
command_name check_esx3_host
command_line $USER1$/check_esx3.pl -H "$HOSTADDRESS$" -f "$ARG1$" -l "$ARG2$" $ARG3$
command_name check_exchange_rbl
command_line $USER1$/check_bl -H $HOSTADDRESS$ $ARG1$
command_name check_file_service
command_line $USER1$/folder_watch.pl $ARG1$ $ARG2$ -f
command_name check_file_size_age
command_name check_ftp
command_line $USER1$/check_ftp -H $HOSTADDRESS$ $ARG1$
command_name check_ftp_fully
command_line $USER1$/check_ftp_fully "$ARG1$" "$ARG2$" "$ARG3$" $HOSTNAME$
command_name check_hpjd
command_line $USER1$/check_hpjd -H $HOSTADDRESS$ $ARG1$
command_name check_http
command_line $USER1$/check_http -I $HOSTADDRESS$ $ARG1$
command_name check_icmp
command_line $USER1$/check_ping -H $HOSTADDRESS$ -w $ARG1$ -c $ARG2$
command_name check_imap
command_line $USER1$/check_imap -H $HOSTADDRESS$ $ARG1$
command_name check_local_disk
command_line $USER1$/check_disk -w $ARG1$ -c $ARG2$ -p $ARG3$
command_name check_local_load
command_line $USER1$/check_load -w $ARG1$ -c $ARG2$
command_name check_local_mrtgtraf
command_line $USER1$/check_mrtgtraf -F $ARG1$ -a $ARG2$ -w $ARG3$ -c $ARG4$ -e $ARG5$
command_name check_local_procs
command_line $USER1$/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$
command_name check_local_swap
command_line $USER1$/check_swap -w $ARG1$ -c $ARG2$
command_name check_local_users
command_line $USER1$/check_users -w $ARG1$ -c $ARG2$
command_name check_mailserver_rbl
command_name check_mongodb_database
command_line $USER1$/check_mongodb.py -H $HOSTADDRESS$ -A $ARG1$ -P $ARG2$ -W $ARG3$ -C $ARG4$ -u $ARG5$ -p $ARG6$ -d $ARG7$ -D
command_name check_mongodb_server
command_line $USER1$/check_mongodb.py -H $HOSTADDRESS$ -A $ARG1$ -P $ARG2$ -W $ARG3$ -C $ARG4$ -u $ARG5$ -p $ARG6$ -D --all-databases
command_name check_mountpoint
command_line $USER1$/check_mountpoints.sh $ARG1$
command_name check_nagiosxi_performance
command_line /usr/bin/php $USER1$/check_nagios_performance.php $ARG1$ $ARG2$ $ARG3$
command_name check_nagios_performance
command_line $USER1$/check_nagios_performance -o $ARG1$ $ARG2$
command_name check_none
command_line /bin/true
command_name check_nrpe
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c $ARG1$ $ARG2$
command_name check_nrpeversion
command_name check_nt
command_line $USER1$/check_nt -H $HOSTADDRESS$ -p $USER7$ -s $USER8$ -v $ARG1$ $ARG2$
command_name check_php_snmp_bandwidth
command_line $USER1$/get_snmp.php -H=$HOSTADDRESS$ -C=$ARG1$ -2 -I=$ARG2$ -u -w=$ARG3$ -c=$ARG4$ -d=$ARG5$
command_name check_ping
command_line $USER1$/check_ping -H $HOSTADDRESS$ -w $ARG1$ -c $ARG2$ -p 5
command_name check_pop
command_line $USER1$/check_pop -H $HOSTADDRESS$ $ARG1$
command_name check_proc_usage
command_line $USER1$/check_proc_usage -p $ARG1$ $ARG2$
command_name check_radius_server_py
command_line $USER1$/check_radius.py -H $HOSTADDRESS$ $ARG1$
command_name check_smtp
command_line $USER1$/check_smtp -H $HOSTADDRESS$ $ARG1$
command_name check_snmp
command_line $USER1$/check_snmp -H $HOSTADDRESS$ $ARG1$
command_name check_snmp_int
command_line $USER1$/check_snmp_int.pl -H $HOSTADDRESS$ -C $ARG1$ -2 -n $ARG2$ -f -k -w $ARG3$ -c $ARG4$ $ARG5$
command_name check_ssh
command_line $USER1$/check_ssh $ARG1$ $HOSTADDRESS$
command_name check_tcp
command_line $USER1$/check_tcp -H $HOSTADDRESS$ -p $ARG1$ $ARG2$
command_name check_tftp_connect
command_line $USER1$/check_tftp.sh --connect $ARG1$
command_name check_tftp_get
command_line $USER1$/check_tftp.sh --get $ARG1$ '$ARG2$' $ARG3$
command_name check_udp
command_line $USER1$/check_udp -H $HOSTADDRESS$ -p $ARG1$ $ARG2$
command_name check_xi_by_ssh
command_line $USER1$/check_by_ssh -H $HOSTADDRESS$ $ARG1$ $ARG2$
command_name check_xi_check_postgres_query
command_line $USER1$/check_http -H $HOSTADDRESS$ -r '$ARG1$' -u '$ARG2$' $ARG3$
command_name check_xi_domain_v2
command_line $USER1$/check_domain.php -d $ARG1$ $ARG2$ $ARG3$
command_name check_xi_host_http
command_line $USER1$/check_http -H $HOSTADDRESS$ $ARG1$
command_name check_xi_host_ping
command_line $USER1$/check_icmp -H $HOSTADDRESS$ -w $ARG1$,$ARG2$ -c $ARG3$,$ARG4$ -p 5
command_name check_xi_mssql_database
command_line $USER1$/check_mssql_database.py -H $HOSTADDRESS$ $ARG1$
command_name check_xi_mssql_query
command_line $USER1$/check_mssql -H $HOSTADDRESS$ $ARG1$
command_name check_xi_mssql_server
command_line $USER1$/check_mssql_server.py -H $HOSTADDRESS$ $ARG1$
command_name check_xi_mysql_health
command_line $USER1$/check_mysql_health $ARG1$
command_name check_xi_mysql_query
command_name check_xi_nagiosxiserver
command_line /usr/bin/php $USER1$/check_nagiosxiserver.php $ARG1$
command_name check_xi_ncpa
command_line $USER1$/check_ncpa.py -H $HOSTADDRESS$ $ARG1$
command_name check_xi_nna
command_line $USER1$/check_nna.py -H $HOSTADDRESS$ -K $ARG1$ $ARG2$
command_name check_xi_oraclequery
command_line /usr/bin/env LD_LIBRARY_PATH=/usr/lib/oracle/11.2/client/lib ORACLE_HOME=/usr/lib/oracle/11.2/client $USER1$/check_oracle_health $ARG1$
command_name check_xi_oracleserverspace
command_name check_xi_oracletablespace
command_name check_xi_postgres
command_line $USER1$/check_postgres.pl $ARG1$
command_name check_xi_postgres_db
command_name check_xi_postgres_query
command_name check_xi_service_dns
command_line $USER1$/check_dns -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_dnsquery
command_line $USER1$/check_dns $ARG1$
command_name check_xi_service_ftp
command_name check_xi_service_hpjd
command_line $USER1$/check_hpjd -H $HOSTADDRESS$ -C $ARG1$
command_name check_xi_service_http
command_name check_xi_service_http_cert
command_line $USER1$/check_http -H $HOSTADDRESS$ -C $ARG1$
command_name check_xi_service_http_content
command_line $USER1$/check_http -H $HOSTADDRESS$ --onredirect=follow -s "$ARG1$"
command_name check_xi_service_ifoperstatus
command_line $USER1$/check_ifoperstatus -H $HOSTADDRESS$ -C $ARG1$ -k $ARG2$ $ARG3$
command_name check_xi_service_ifoperstatusnag
command_line $USER1$/check_ifoperstatnag $ARG1$ $ARG2$ $HOSTADDRESS$
command_name check_xi_service_imap
command_name check_xi_service_ldap
command_line $USER1$/check_ldap -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_mrtgtraf
command_line $USER1$/check_rrdtraf -f /var/lib/mrtg/$ARG1$ -w $ARG2$ -c $ARG3$ -l $ARG4$
command_name check_xi_service_nagioslogserver
command_line $USER1$/check_nagioslogserver.php $ARG1$
command_name check_xi_service_none
command_line $USER1$/check_dummy 0 "Nothing to monitor"
command_name check_xi_service_nsclient
command_line $USER1$/check_nt -H $HOSTADDRESS$ -s "$ARG1$" -p 12489 -v $ARG2$ $ARG3$ $ARG4$
command_name check_xi_service_ping
command_name check_xi_service_pop
command_name check_xi_service_smtp
command_name check_xi_service_snmp
command_name check_xi_service_snmp_linux_load
command_line $USER1$/check_snmp_load_wizard.pl -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_snmp_linux_process
command_line $USER1$/check_snmp_process_wizard.pl -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_snmp_linux_storage
command_line $USER1$/check_snmp_storage_wizard.pl -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_snmp_watchguard
command_line $USER1$/check_snmp_generic.pl -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_snmp_win_load
command_line $USER1$/check_snmp_load.pl -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_snmp_win_process
command_line $USER1$/check_snmp_process.pl -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_snmp_win_service
command_line $USER1$/check_snmp_win.pl -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_snmp_win_storage
command_line $USER1$/check_snmp_storage.pl -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_ssh
command_name check_xi_service_status
command_line sudo /usr/local/nagiosxi/scripts/manage_services.sh status $ARG1$
command_name check_xi_service_tcp
command_line $USER1$/check_tcp -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_udp
command_line $USER1$/check_udp -H $HOSTADDRESS$ $ARG1$
command_name check_xi_service_webinject
command_line $USER1$/check_webinject.sh $ARG1$
command_name check_xi_service_wmiplus
command_line $USER1$/check_wmi_plus.pl -H $HOSTADDRESS$ -u $ARG1$ -p $ARG2$ -m $ARG3$ $ARG4$
command_name check_xi_service_wmiplus_authfile
command_line $USER1$/check_wmi_plus.pl -H $HOSTADDRESS$ -A $ARG1$ -m $ARG2$ $ARG3$
command_name check_xi_sla
command_line $USER1$/check_xisla.php $ARG1$
command_name notify-host-by-email
command_line /usr/bin/printf "%b" "***** Nagios Monitor XI Alert *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /bin/mail -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
command_line /usr/bin/printf "%b" "***** Nagios Monitor XI Alert *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$" | /bin/mail -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
command_name process-host-perfdata-file-bulk
command_line /bin/mv /usr/local/nagios/var/host-perfdata /usr/local/nagios/var/spool/xidpe/$TIMET$.perfdata.host
command_name process-host-perfdata-file-pnp-bulk
command_line /bin/mv /usr/local/nagios/var/host-perfdata /usr/local/nagios/var/spool/perfdata/host-perfdata.$TIMET$
command_name process-host-perfdata-pnp-normal
command_line /usr/bin/perl /usr/local/nagios/libexec/process_perfdata.pl -d HOSTPERFDATA
command_name process-service-perfdata-file-bulk
command_line /bin/mv /usr/local/nagios/var/service-perfdata /usr/local/nagios/var/spool/xidpe/$TIMET$.perfdata.service
command_name process-service-perfdata-file-pnp-bulk
command_line /bin/mv /usr/local/nagios/var/service-perfdata /usr/local/nagios/var/spool/perfdata/service-perfdata.$TIMET$
command_name process-service-perfdata-pnp-normal
command_name xi_host_event_handler
command_line /usr/bin/php /usr/local/nagiosxi/scripts/handle_nagioscore_event.php --handler-type=host --host="$HOSTNAME$" --hostaddress="$HOSTADDRESS$" --hoststate=$HOSTSTATE$ --hoststateid=$HOSTSTATEID$ --lasthoststate=$LASTHOSTSTATE$ --lasthoststateid=$LASTHOSTSTATEID$ --hoststatetype=$HOSTSTATETYPE$ --currentattempt=$HOSTATTEMPT$ --maxattempts=$MAXHOSTATTEMPTS$ --hosteventid=$HOSTEVENTID$ --hostproblemid=$HOSTPROBLEMID$ --hostoutput="$HOSTOUTPUT$" --longhostoutput="$LONGHOSTOUTPUT$" --hostdowntime=$HOSTDOWNTIME$
command_name xi_host_notification_handler
command_line /usr/bin/php /usr/local/nagiosxi/scripts/handle_nagioscore_notification.php --notification-type=host --contact="$CONTACTNAME$" --contactemail="$CONTACTEMAIL$" --type=$NOTIFICATIONTYPE$ --escalated="$NOTIFICATIONISESCALATED$" --author="$NOTIFICATIONAUTHOR$" --comments="$NOTIFICATIONCOMMENT$" --host="$HOSTNAME$" --hostaddress="$HOSTADDRESS$" --hostalias="$HOSTALIAS$" --hostdisplayname="$HOSTDISPLAYNAME$" --hoststate=$HOSTSTATE$ --hoststateid=$HOSTSTATEID$ --lasthoststate=$LASTHOSTSTATE$ --lasthoststateid=$LASTHOSTSTATEID$ --hoststatetype=$HOSTSTATETYPE$ --currentattempt=$HOSTATTEMPT$ --maxattempts=$MAXHOSTATTEMPTS$ --hosteventid=$HOSTEVENTID$ --hostproblemid=$HOSTPROBLEMID$ --hostoutput="$HOSTOUTPUT$" --longhostoutput="$LONGHOSTOUTPUT$" --datetime="$LONGDATETIME$"
command_name xi_service_event_handler
command_line /usr/bin/php /usr/local/nagiosxi/scripts/handle_nagioscore_event.php --handler-type=service --host="$HOSTNAME$" --service="$SERVICEDESC$" --hostaddress="$HOSTADDRESS$" --hoststate=$HOSTSTATE$ --hoststateid=$HOSTSTATEID$ --hosteventid=$HOSTEVENTID$ --hostproblemid=$HOSTPROBLEMID$ --servicestate=$SERVICESTATE$ --servicestateid=$SERVICESTATEID$ --lastservicestate=$LASTSERVICESTATE$ --lastservicestateid=$LASTSERVICESTATEID$ --servicestatetype=$SERVICESTATETYPE$ --currentattempt=$SERVICEATTEMPT$ --maxattempts=$MAXSERVICEATTEMPTS$ --serviceeventid=$SERVICEEVENTID$ --serviceproblemid=$SERVICEPROBLEMID$ --serviceoutput="$SERVICEOUTPUT$" --longserviceoutput="$LONGSERVICEOUTPUT$" --servicedowntime=$SERVICEDOWNTIME$
command_name xi_service_notification_handler
command_line /usr/bin/php /usr/local/nagiosxi/scripts/handle_nagioscore_notification.php --notification-type=service --contact="$CONTACTNAME$" --contactemail="$CONTACTEMAIL$" --type=$NOTIFICATIONTYPE$ --escalated="$NOTIFICATIONISESCALATED$" --author="$NOTIFICATIONAUTHOR$" --comments="$NOTIFICATIONCOMMENT$" --host="$HOSTNAME$" --hostaddress="$HOSTADDRESS$" --hostalias="$HOSTALIAS$" --hostdisplayname="$HOSTDISPLAYNAME$" --service="$SERVICEDESC$" --hoststate=$HOSTSTATE$ --hoststateid=$HOSTSTATEID$ --servicestate=$SERVICESTATE$ --servicestateid=$SERVICESTATEID$ --lastservicestate=$LASTSERVICESTATE$ --lastservicestateid=$LASTSERVICESTATEID$ --servicestatetype=$SERVICESTATETYPE$ --currentattempt=$SERVICEATTEMPT$ --maxattempts=$MAXSERVICEATTEMPTS$ --serviceeventid=$SERVICEEVENTID$ --serviceproblemid=$SERVICEPROBLEMID$ --serviceoutput="$SERVICEOUTPUT$" --longserviceoutput="$LONGSERVICEOUTPUT$" --datetime="$LONGDATETIME$"
# END OF FILE
