DISK CRITICAL - Problem filesysteme /data
yza
Post by yza »
Hi
I have just installed my first platform NAGIOS CORE.
That works very well :) , I monitor 2 Windows servers and 2 redhat servers for the moment.
I have a small problem on my redhat Linux servers.
I can watch with no problem at all filesysteme/, / the Var, / opt, / boot but filesysteme / data and / dumps do not work.
I have the message below
DISK CRITICAL - /data is not accessible: No such file or directory
DISK CRITICAL - /dumps is not accessible: No such file or directory
I do not understand, filesysteme I exist also tried with /dev/cciss/c0d0p7 it doesn’twork
Have you an idea? :idea:
Thank you very much
Isabelle
Re: DISK CRITICAL - Problem filesysteme /data
Are this mounted shares? If this is the case you may need to be sure the nagios user has access to them.
yza
Post by yza »
Hi scottwilkerson,
It's not mounted shares, it's local filesysteme
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/cciss/c0d0p2 5039616 3126544 1657072 66% /
tmpfs 16438600 0 16438600 0% /dev/shm
/dev/cciss/c0d0p1 495844 37681 432563 9% /boot
/dev/cciss/c0d0p7 266556208 139712360 113303496 56% /data
/dev/cciss/c0d0p3 5039616 1204840 3578776 26% /opt
/dev/cciss/c0d0p6 2015824 166352 1747072 9% /var
Yes the user is in the group for acces to /data ...
On the machine in question can you execute the following command and report the output
sudo su nagios -c "/usr/local/nagios/libexec/check_disk  -w 10% -c 5% -p /data"
yza
Post by yza »
Hi scottwilkerson,
Attached the result of the command :
[root@orion linux-nrpe-agent]# sudo su nagios -c "/usr/local/nagios/libexec/check_disk -w 10% -c 5% -p /data"
DISK OK - free space: /data 110647 MB (44.78% inode=100%);| /data=136437MB;234277;247292;0;260308
best reagards
Isabelle
That appears to be working fine,m can you show the command that you are using from your nagios server that is producing?
