log file in /usr/local/nagios/var/archives
xlin125
Post by xlin125 »
We have Nagios XI 5.2.3 installed on a Redhat 6.8 system. In the /usr/local/nagios/var/archives directory, there is a log file per day that contains the measurements for all the managed hosts. In the this daily log file, there is a CPU usage measurement for a host that is monitored with a Nagios service for CPU, a SWAP usage measurement for a host that is monitored with a Nagios service for SWAP usage, and so on. Here are some samples:
$ grep zakr1scpx01bex001 /usr/local/nagios/var/archives/nagios-09-25-2017-00.log |grep CPU |grep "CURRENT SERVICE STATE"
[1506211200] CURRENT SERVICE STATE: zakr1scpx01bex001;CPU_load_vm_8cpu;OK;HARD;1;OK - load average: 0.12, 0.17, 0.16
$ grep zakr1scpx01bex001 /usr/local/nagios/var/archives/nagios-09-26-2017-00.log |grep CPU |grep "CURRENT SERVICE>
[1506297600] CURRENT SERVICE STATE: zakr1scpx01bex001;CPU_load_vm_8cpu;OK;HARD;1;OK - load average: 0.08, 0.09, 0.08
$ grep zakr1scpx01bex001 /usr/local/nagios/var/archives/nagios-09-22-2017-00.log |grep SWAP |grep "CURRENT SERVIC>
[1505952000] CURRENT SERVICE STATE: zakr1scpx01bex001;Swap_util_vm;OK;HARD;1;SWAP OK - 100% free (16383 MB out of 16383 MB)
$ grep zakr1scpx01bex001 /usr/local/nagios/var/archives/nagios-09-23-2017-00.log |grep SWAP |grep "CURRENT SERVIC>
[1506038400] CURRENT SERVICE STATE: zakr1scpx01bex001;Swap_util_vm;OK;HARD;1;SWAP OK - 100% free (16383 MB out of 16383 MB)
Is this the CPU usage measurement from the last CPU usage polling on the host of the day, or it is the average CPU usage on the host of the day? The "CURRENT SERVICE STATE" in the line seems implying this is the CPU usage at the moment when the Nagios service for CPU runs and reports for the host. At the end of the day, the last run of the Nagios service for CPU usage is logged to this file. Please clarify it. Thanks!
gwakem
Re: log file in /usr/local/nagios/var/archives
Post by gwakem »
These files seem to contain a dump of the Nagios status information post logotate, and then the result of every status check, as well as notifications, etc, for that day. So to answer your question (I think,) the number results you are looking at should reflect a point in time result of a status check, unless you specifically have a plugin that does some sort of special calculation and provides the daily average based on SAR or something.
Griffin Wakem
xlin125
Post by xlin125 »
Thanks @gwakem for the clarification!
