missing logos graphics for hosts
Hello all,
im new to nagios - decided to upgrade from 3.5.1 to the latest 4.x release.
in doing so, i copied alot of the nagios 3 configurations because they worked fine, and everything works great.
except, im missing the host logo graphics? im having trouble locating this particular file or what line i should edit. i've been at it off and on for several hours and having no luck.
can anyone point me in the right direction?
thanks
thanks
kyang
Re: missing logos graphics for hosts
Are you on CentOS? In Nagios 4 the path to the logos is
There are images and logos available on the Nagios Exchange if you somehow don't have any.
https://exchange.nagios.org/directory/G ... -and-Logos
/usr/local/nagios/share/images/logoshttps://exchange.nagios.org/directory/G ... -and-Logos
im on ubuntu 16.04 LTS
the path is the same - i built from source.
that directory is correct, i can navigate to it on the command line, but apache is missing this little piece of information somehow. is it the cgi.cfg? or in the apache sites-enabled or .. even apache/conf-enabled directory?
Not Found
The requested URL /nagios/images/logos/base/ubuntu.png was not found on this server.
- here's a screenshot of what im seeing
- brokenlinks.PNG (3.38 KiB) Viewed 8895 times
kyang
If you go into your cgi.cfg, or if you wanted to post your whole cgi.cfg that's fine too.
What path does it show for #PHYSICAL HTML PATH
Mine looks something like this,
It could be a path issue, but let us know!
# PHYSICAL HTML PATH
# This is the path where the HTML files for Nagios reside. This
# value is used to locate the logo images needed by the statusmap
# and statuswrl CGIs.
physical_html_path=/usr/local/nagios/share
that was the first line i checked.
the cgi.cfg line is basically default minus some user authorization lines.
but for the /etc/apache2/conf-enabled/nagios4.conf file - its a link to 'apache2.conf' in /usr/local/nagios/etc/
i need this for active directory authentication.
i removed my domain portion, but here is where i'm wondering where i'm screwed up.
i borrowed this from nagios 3 but matched up what knew would need to be changed for my new better nagios 4 installation.
#Apache configuration for nagios 4.x
# note to users of nagios 1.x and 2.x:
# throughout this file are commented out sections which preserve
# backwards compatibility with bookmarks/config for older nagios versios.
# simply look for lines following "nagios 1.x:" and "nagios 2.x" comments.
#ScriptAlias /cgi-bin/nagios /usr/local/nagios/sbin
# Where the stylesheets (config files) reside
Alias /nagios/share/stylesheets /usr/local/nagios/share/stylesheets
# Where the HTML pages live
Alias /nagios /usr/local/nagios/share/
<DirectoryMatch (/usr/local/nagios/share|/usr/local/nagios/sbin|/usr/local/nagios/share/stylesheets)>
Options FollowSymLinks
DirectoryIndex index.php index.html
AllowOverride AuthConfig
Order Allow,Deny
Allow From All
AuthName "Nagios Access"
AuthType Basic
AuthUserFile /usr/local/nagios/etc/htpasswd.users
# nagios 1.x:
#AuthUserFile /usr/local/nagios/etc/htpasswd.users
require valid-user
AuthBasicProvider ldap
# AuthzLDAPAuthoritative off
AuthLDAPUrl ldap://localhost/DC=xxxxxxxxx,DC=xxxxx?SAMAccountName
require user xxxxxx
</DirectoryMatch>
<Directory /usr/local/nagios/share>
#<Directory /usr/share/nagios/htdocs>
Options +ExecCGI
</Directory>
Order Allow,Deny
Allow From All
AuthType Basic
# nagios 1.x:
require valid-user
require user xxxxxx
</DirectoryMatch>
Options +ExecCGI
</Directory>
It looks like somehow your server is looking for them in a subdirectory called base under the normal pathdanyol5 wrote:Not Found
Just to test a theory can you do the following:
cd /usr/local/nagios/share/images/logos
mkdir base -p
cp *.* baseRe: missing logos graphics for hosts
the actual directory for the/usr/share/nagios/htdocs/images/logos/base
this directory does not actually have the ubuntu logo.
/usr/local/nagios/share/images/logos/
i'd make a link to the other directory, but i dont think that would be prefered...
i think i made sense of it, one directory was from nagios 3 installation.
i moved the 'base' directory into the correct directory.
i'm all good now
- slight confusing on my end since i installed nagios 4 in parallel to nagios 3 running.
thanks for your help however.
i'm all good now
Glad to hear it is sorted
