NSclient++ check_eventlog
very_best
Post by very_best »
Hello!
I want to check the Windows Event log but I don't want to get out performance-date. Their is a possibilty with perf-config. Default: perf-config=level(ignored:true)
If I set the value to false I also get the perf-data:
/usr/lib/nagios/plugins/check_nrpe -t 50 -H <Servername/IP> -c check_eventlog -a file=application scan-range=-50m "filter=id=2009 or id=2937" "warning=id=2009 or id=2937" "critical=none" "top-syntax=%(status): %(count) message(s) found for id(s) 2009, 2937" "perf-config=level(ignored:false)"
WARNING: 3 message(s) found for id(s) 2009, 2937|'Application_MSExchange Mid-Tier Storage_id'=2009;2009;0 'Application_MSExchange Mid-Tier Storage_id'=2009;2009;0 'Application_MSExchange Mid-Tier Storage_id'=2009;2009;0
I have 2 questions:
- 1) What can I do that I don't geht perf-date out?
- 2) If I get PerfData out the perf-Name should have the Name of the Counter and the Id. Example: Application_MSExchange Mid-Tier Storage_id_2009'=3;10;20.
What do I have to change that I get this output?
dwasswa
Re: NSclient++ check_eventlog
Post by dwasswa »
For,
change perf-config=level(ignored:true)
to
very_best
Post by very_best »
Hello!
1) thank for answer!
does anyone can give me an answer for 2nd question?
rg
Hansi
Post by mcapra »
The NSClient++ forums are likely a better place to discuss specifics.
perf-syntax is most likely the appropriate directive for such changes. The documentation for the check_eventlog command shows the available key/value pairs:
https://docs.nsclient.org/reference/win ... erf-syntax
Thanks @mcapra for the help.
@very_best, if have any more questions, post them here.
