I want to add a map in "view" but it's not fonctional .
The error is " The parameter "show" does not match the valid value format" .
adding a map in "view"
kyang
Re: adding a map in "view"
Could you tell us what map you want to add? Or what you are typing in.
Any details on this and its function will help us.
Usually, it takes a URL if you are wanting to add another view to another website? I'll show you my example and also the documentation on understanding the views tab.
https://assets.nagios.com/downloads/nag ... _Views.pdf
