Nagios XI Rest API
bennyboy
Nagios XI Rest API
Post by bennyboy »
I don't find option for managing hostgroup member. (Add, remove, update). There a way to do it ?
I also want to know if it's possible to show only the field I need in the response ?
I find a section about Building Limited Queries in the documentation but I don't find a way to limit the field.
Example :
Query right now :
    "hoststatuslist": {
        "recordcount": "12",
        "hoststatus": [
                "@attributes": {
                    "id": "401"
                "instance_id": "1",
                "host_id": "202",
                "name": "tset",
                "display_name": "tset",
                "address": "127.0.53.53",
                "alias": "tset",
                "status_update_time": "2015-09-24 02:05:51",
                "status_text": "OK - 127.0.53.53: rta 0.021ms, lost 0%",
                "status_text_long": "",
                "current_state": "0",
                "icon_image": "server.png",
                "icon_image_alt": "",
                "performance_data": "rta=0.021ms;3000.000;5000.000;0; pl=0%;80;100;; rtmax=0.060ms;;;; rtmin=0.011ms;;;;",
                "should_be_scheduled": "1",
                "check_type": "0",
                "last_state_change": "2015-09-22 12:11:41",
                "last_hard_state_change": "2015-09-22 12:11:41",
                "last_hard_state": "0",
                "last_time_up": "2015-09-24 02:05:51",
                "last_time_down": "1969-12-31 18:00:00",
                "last_time_unreachable": "1969-12-31 18:00:00",
                "last_notification": "1969-12-31 18:00:00",
                "next_notification": "1969-12-31 18:00:00",
                "no_more_notifications": "0",
                "acknowledgement_type": "0",
                "current_notification_number": "0",
                "event_handler_enabled": "1",
                "process_performance_data": "1",
                "obsess_over_host": "1",
                "modified_host_attributes": "0",
                "event_handler": "",
                "check_command": "check_xi_host_ping!3000.0!80%!5000.0!100%",
                "normal_check_interval": "40",
                "retry_check_interval": "5",
                "check_timeperiod_id": "128",
                "has_been_checked": "1",
                "current_check_attempt": "1",
                "max_check_attempts": "4",
                "last_check": "2015-09-24 02:05:51",
                "next_check": "2015-09-24 02:45:51",
                "state_type": "1",
                "notifications_enabled": "0",
                "problem_acknowledged": "0",
                "passive_checks_enabled": "1",
                "active_checks_enabled": "1",
                "flap_detection_enabled": "1",
                "is_flapping": "0",
                "percent_state_change": "0",
                "latency": "0",
                "execution_time": "0.00226",
                "scheduled_downtime_depth": "0"
I need only
    "hoststatuslist": {
        "hoststatus": [
                "@attributes": {
                    "id": "401"
                "host_id": "202",
                "name": "tset",
Thank you!
Re: Nagios XI Rest API
In the help section of XI click "Config Reference" then on the right select "POST config/hostgroup" this describes what you are looking to do for Adding.
Removing and updating is coming in a future release.
bennyboy
Post by bennyboy »
What is the best way to manage hostgroup members ?
Add it to by hostsgroups api or hosts api ?
Thank you!
It becomes much easier through the api if you add them to the host.
But other than that it is personal preference.
bennyboy
Post by bennyboy »
it's possible to when I ask the API to return only the field I need ???
bennyboy wrote:it's possible to when I ask the API to return only the field I need ???
It is going to give you the whole objects, but the fields are named, you would just need to parse the object to get the value for the field you are looking for.
