Hey guys!
Is it possible to integrate nagiosxi with the onpage paging system, and if it does is there any documentation out there for setting it up?
Nagios and onpage
Nagios and onpage
Proudly running:
Nagios Network Analyser
Nagios Fusion
Nagios Fusion
Re: Nagios and onpage
I'm not familiar with onpage but it looks like THEY have created an integration.
https://www.onpage.com/nagios-integration/
Also, being they lifted the image they are using that shows XI right off our website, I'm sure they have an integration for that too.
