How do I export, say, D: Drive usage, monitoring data into a spreadsheet? I can get a report in pdf format, but would like it in excel.
Thanks!
How do I export data into spreadsheet
caterpillartce
Re: How do I export data into spreadsheet
On the top right of any of the performance graphs if you click the 3 line menu, you will have an option to download as an image or CSV, XML, JSON.
CSV will open in a spreadsheet
caterpillartce
Thank you! I did notice that option, but it seems to be per host and we have ~160 hosts so I am looking for a solution that I don't have to export 160 times. Thanks!
We do not have that build-in but I believe it is being added to the API in future versions
