Error after Apply configuration
perryell
Post by perryell »
We have a problem applying changes to the configuration . We are getting
An error occurred while attempting to apply your configuration to Nagios Core.Configurations failed to write to file. Monitoring engine configuration files have been rolled back to their last known good checkpoint.
The snapshot is not showing any error we can trace for today
When I tried tool-write config files- write monitoring data/check config i dont see any error, checking configuration files with -v option return success
I tried a couple of things..restart nagios/nagiosxi, reboot the server and repair the database..no luck
Can you help to troubleshoot?
Re: Error after Apply configuration
Let's try this, log in to your XI server as root and run the following
/usr/local/nagiosxi/scripts/reset_config_perms
Then this
 reconfigure_nagios.sh &> reconfig.txt
Then if you could post the reconfig.txt we'll have a look
perryell
Post by perryell »
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://loca
lhost/nagiosql/index.php --no-check-certificate --post-data 'Submit=Login&tfUser
name=nagiosxi&tfPassword=xxxx' -O nagiosql.loginLOGIN SUCCESSFUL!
IMPORTING CONFIG FILES...Array
RESETTING PERMS
SETUID ROOT OK
URL: http://localhost/nagiosql/index.php
CMDLINE
name=nagiosxi&tfPassword=xxxxx' -O nagiosql.loginLOGIN SUCCESSFUL!
URL: http://localhost/nagiosql/admin/verify.php
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/ve
rify.php --no-check-certificate --post-data 'writeMonitoring=Go' -O nagiosql.exp
ort.monitoring
NAGIOSQL WRITE CONFIGS FAILED!\n
Can we do the following:
cd /tmp
wget http://assets.nagios.com/downloads/nagiosxi/scripts/NagiosXI-FixPerms.sh
chmod +x NagiosXI-FixPerms.sh
./NagiosXI-FixPerms.sh
Then
./reconfigure_nagios.sh &> reconfig.txt
If you could attach the whole reconfig.txt file that would be great because the board eats some of what you paste in.
perryell
Post by perryell »
file attached
Ok, let's go back to the web interface and I would like to to do the following:
Configure -> Core Config Manager -> Tools -> Write Config Files
We are going to click go on each of these from the top down until we get an error, and then report back with any errors.
perryell
Post by perryell »
Writing monitoring data--after two minues replays with a blank page..no error, zero info, page only contains the "nagios Core Config manager" header
writing additional data
Write timeperiods.cfg ...
Configuration file successfully written!
Write commands.cfg ...
Write contacts.cfg ...
Write contactgroups.cfg ...
Write contacttemplates.cfg ...
Write servicedependencies.cfg ...
Write hostdependencies.cfg ...
Write serviceescalations.cfg ...
Write hostescalations.cfg ...
Write serviceextinfo.cfg ...
Write hostextinfo.cfg ...
Check configuration files
Total Warnings: 44
Total Errors: 0
Restart nagios
restart without problems
mguthrie
Post by mguthrie »
I suspect you're hitting either a timeout or memory limit with PHP, I'm guessing it's a larger set of configs that you're applying. Take a look at this wiki and see if it resolves the issue:
http://support.nagios.com/wiki/index.ph ... _Completes
perryell
Post by perryell »
Bingo!
The memory was set to 512M, but the timeout was set to 60, i increased both to 120, the files are written now and configuration applied successfully
Thanks for all your help..happy new year :D
Glad to see you got it working. Happy New Year to you as well!
