Monitor several folders size in Windows
lpereira
Post by lpereira »
Hello all:
This is related this post https://support.nagios.com/forum/viewto ... 16&t=45210
i was able to monitor a Windows folder by his size. however i'm unable to figure out how to monitor multiple folders
i have downloaded the script from here:
https://exchange.nagios.org/directory/P ... bs/details
Set WshShell = WScript.CreateObject("WScript.Shell")
If WScript.Arguments.Length = 0 Then
  Set ObjShell = CreateObject("Shell.Application")
  ObjShell.ShellExecute "wscript.exe" _
    , """" & WScript.ScriptFullName & """ RunAsAdministrator", , "runas", 1
  WScript.Quit
End if
Dim strfolder
Dim intwarning
Dim intcritic
Dim wsh
Dim intvelkost
Dim intjednotka
Dim Perf_Data
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set wsh = CreateObject("WScript.Shell")
If Wscript.Arguments.Count = 3 Then
strfolder = Wscript.Arguments(0)
intwarning = Wscript.Arguments(1)
intcritic = Wscript.Arguments(2)
Set objFolder = objFSO.GetFolder(strfolder)
intjednotka = 1048576 '1MB->bytes'
intvelkost = objFolder.Size/intjednotka
Perf_Data = "|'FolderSize'=" & round (objFolder.Size / 1048576,1) & "MB;"
if (objFolder.Size/1024000) > Cint(intcritic) then
Wscript.Echo "CRITICAL:" & round (objFolder.Size / 1048576,1) & " MB" & Perf_Data
Wscript.Quit(2)
elseif (objFolder.Size/1048576) > Cint(intwarning) then
Wscript.Echo "WARNING:" & round (objFolder.Size / 1048576,1) & " MB" & Perf_Data
Wscript.Quit(1)
else
Wscript.Echo "OK:" & round (objFolder.Size /1048576,1) & " MB" & Perf_Data
Wscript.Quit(0)
end if
else
Wscript.Echo "UNKNOWN:"& strfolder &"-" & intwarning & "-" & intcritic
Wscript.Quit(3)
End If
what i did is add the folder path in nsclient.ini
; A list of scripts available to run from the CheckExternalScripts module. Syntax is: <command>=<script> <arguments>
check_foldersize=C:\windows\System32\cscript.exe //NoLogo //T:30 "C:\Program Files\nsclient++\scripts\check_folder_size.vbs" "E:\System Volume Information" 8192 5120
i have tried to add a similar line below pointing to the same folder on drive G but i got only one output when i run the command Nagios Side.
can anyone tell me how can i get this working?
thanks
cdienger
Re: Monitor several folders size in Windows
Post by cdienger »
Can you attach the similar line that you added as well as the command you're running on the XI side?
It sounds like commands that you're running on XI probably point to the same command in the ini file.
lpereira
Post by lpereira »
cdienger wrote:Can you attach the similar line that you added as well as the command you're running on the XI side?
what i'm running is
 ./check_nrpe -H ServerIP -t 30 -c check_foldersize -n
and the return is (for instance)
CRITICAL:218709.9 MB|'FolderSize'=218709.9MB
cdienger
Post by cdienger »
In that case it will only run one of the definitions in the ini file. You'll want to do something like:
    check_foldersize=C:\windows\System32\cscript.exe //NoLogo //T:30 "c:\program files\nsclient++\scripts\check_folder_size.vbs" "$ARG1$" 50 78
and then specify the folder when you run the command:
./check_nrpe -H NSCLIENTIP -c check_foldersize -a "c:\program files\nsclient++"
lpereira
Post by lpereira »
cdienger wrote:In that case it will only run one of the definitions in the ini file. You'll want to do something like:
i'm getting the following error linux side
 ./check_nrpe -H SERVERIP -c check_foldersize -a "F:\System Volume Information" -n
Exception processing request: Request contained arguments (not currently allowed, check the allow arguments option).
i did what you recommended on the nsclient file
check_foldersize=C:\windows\System32\cscript.exe //NoLogo //T:30 "c:\program files\nsclient++\scripts\check_folder_size.vbs" "$ARG1$" 8192 5120
[/settings/external scripts/alias]
check_folder_size.vbs=check_foldersize
cdienger
Post by cdienger »
make sure the nsclient.ini file contains:
[/settings/external scripts]
allow arguments = true
allow nasty characters = true
lpereira
Post by lpereira »
cdienger wrote:make sure the nsclient.ini file contains:
yes the nsclient.ini has those two lines
cdienger
Post by cdienger »
Check the entire file for lines starting with allow arguments and allow nasty characters. You man need to set it in a couple places. Make sure to restart the nsclient service after making any changes.
lpereira
Post by lpereira »
Yes i reviewed them all... in some options is set to "0", i changed them to "1" and i got the following msj
[root@Nagios XI libexec]# ./check_nrpe -H IP SERVER -c check_foldersize -a "C:\System Volume Information" -n
So, i assume 0 is correct
you want these to be set to true
Once they all are, you need to restart the NSClient{++ service.
If this still doesn't work, can you attach the nsclient.ini from this windows machine so we can take a look?
Thanks.
