We set up our SonicWall NSA 3500 as a source and initially it was displaying Top 5 Talker data but now the fields are blank. The bandwidth graph is still showing data. The NSA is configured to use NetFlow v9. I have done the nfdump install and reboot NNA but still no change.
No Talker data displayed
- Former Nagios Staff
Re: No Talker data displayed
What version of NNA is this? It may be a bug that has been fixed. Also, are you using SSL?
Using NNA 2.3.0. Could be an SSL issue actually. Thanks.
Please put the following code in /etc/httpd/conf.d/ssl.conf just above </VirtualHost>
The run service httpd restart
Please let us know if that resolves the issue.
RewriteEngine on
RewriteCond $1 !^(index\.php|scripts|media|app|js|css|img|font|vendor|config.js)
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule nagiosna/(.*)$ /var/www/html/nagiosna/www/index.php/$1 [L,QSA]
