So I have encountered an issue which has completely befuddled me. What could cause such behavior is surely a mystery.
I would appreciate someone from support duplicating this scenario as to confirm/reject my testing.
At first I though it might be a system (serverA) specific but after replicating the conditions on serverB it happens exactly the same.
Scenario Description:
NCPA version 2.0.5
InstallDir E:\DCOM\Nagios\NCPA
Install Type (Windows Interactive and Silent)
Configurations Common to both serverA & serverB Attached
Debug Logs to both serverA & serverB Attached
Once the ncpa listener and passive services are up and operational perform the following steps.
Open a Desktop browser (Firefox 56.0) and connect to the remote ncpa listener
Login and then select Live Data -> Top Processes (Works!)
Then open a local Browser (Firefox 56.0) on the remote host where the ncpa listener exists
Login and then select Live Data -> Top Processes (Will not function locally)
Simultaneously the Desktop Browser also stops functioning and if you attempt to select Live Data -> Top Processes again you get no result data.
Parsing the ncpa_listener.log with debug activated you find the following errors.
This is very similar to the Bug Report # 114 on GitHub for NCPA.
2017-10-05 09:54:39,858:ERROR:app:Exception on /ws/top [GET]
Traceback (most recent call last):
File "C:\Python27\lib\site-packages\flask\app.py", line 1817, in wsgi_app
File "C:\Python27\lib\site-packages\flask\app.py", line 1477, in full_dispatch_request
File "C:\Python27\lib\site-packages\flask\app.py", line 1381, in handle_user_exception
File "C:\Python27\lib\site-packages\flask\app.py", line 1475, in full_dispatch_request
File "C:\Python27\lib\site-packages\flask\app.py", line 1461, in dispatch_request
File "C:\ncpa\agent\listener\server.py", line 154, in token_auth_decoration
File "C:\ncpa\agent\listener\server.py", line 667, in top_websocket
File "C:\Python27\lib\json\__init__.py", line 244, in dumps
File "C:\Python27\lib\json\encoder.py", line 207, in encode
File "C:\Python27\lib\json\encoder.py", line 270, in iterencode
UnicodeDecodeError: 'utf8' codec can't decode byte 0xa0 in position 983: invalid start byte
Testing other browsers like IE 11.0 also experiences issues like not being about to display the API json data.
I truly believe some real QA testing is warranted against the NCPA listener if the product is being seriously considered as an agent solution for Nagios XI moving forward. I really like the NCPA agent but must be careful not to demo the issues when trying to sell the product across organizational teams.
Anyway find attached the logs and base common cfg files being utilized.
Would appreciate some feedback from the Support Staff if they are able to replicate the test.
And as always I appreciate all your hard work and dedication,
Danny
