Moderator Edit: This thread has been split from another - https://support.nagios.com/forum/viewto ... 35&t=35139
In the future, please create a new thread and link to the old one instead of adding on.
I know it is an older entry, but I've the same problem on an CENTOS 7 ...
Which further Information is needed to solve the problem?
Segmentation fault (core dumped) (check_dns)
- Former Nagios Staff
Re: Segmentation fault (core dumped) (check_dns)
Are you also on Core 3.5.1? What version of of check_dns? Please give us a tail of /var/log/messages in a code block showing one of the dumps
