ethernet to internet
kniotech
Post by kniotech »
well, I have a pcb board,with ethernet connection, the board measure temp, voltage, current, and other events, then at pre-set time, it boradcast the information on the network built in the software is te IP address 192.168.1 so what ever IP address is given , basically our software and harware work just fine on our network, the question is can we use Nagios in order to display our data ethernet to internetfrom?
mguthrie
Re: ethernet to internet
Post by mguthrie »
This would probably require a custom check. See the plugin development guidelines as to how to make this work with Nagios.
http://nagiosplug.sourceforge.net/devel ... lines.html
