Moderator Edit: This thread has been split from another - https://support.nagios.com/forum/viewto ... =6&t=44172
In the future, please create a new thread and link to the old one instead of adding on.
Hi Experts,
this issue is happening for our client also can anyone help on this.
i have attached the screen shot and system profile as well.
Thanks & Regards,
K Vijay Kumar.
/var/lib/mrtg/.rrd does not exist.
viju.111kammar
Re: /var/lib/mrtg/.rrd does not exist.
How were these services added?
Was the Network Switch/Router Wizard ran to create these?
It also is possible that this switch/router doesn't provide counters for the vlan, and can only perform that for the actual interfaces. If that is the case you will see it is just the vlans that are having the issue
