Nagios Tray Monitor Setup help needed
kwhogster
Post by kwhogster »
Nagios Tray Monitor
Can not get the tray monitor to work
Nagios Tray Monitor 1.0 by Phillip Howar
This page can't be displayed
Make sure the web address is https://nagiosadmin:[email protected] is correct
The app is not getting the correct url
my url is
10.2.8.79/Nagios
I do not have anything in the URL of Nagios cgi-bin directory
Do not know what to put in there
Any ideas
Tom
Re: Nagios Tray Monitor Setup help needed
Post by mcapra »
kwhogster wrote: I do not have anything in the URL of Nagios cgi-bin directory
I don't know a single thing about "Nagios Tray Monitor", but try this:
http://<your_nagios_host>/nagios/cgi-bin/
If the application doesn't have a section for the basic authentication credentials, you may need to provide them in the URL like so:
http://username:password@<your_nagios_host>/nagios/cgi-bin/
If that doesn't work, can you share where you got "Nagios Tray Monitor" from?
Case matters you should use
http://10.2.8.79/nagios/
and
http://10.2.8.79/nagios/cgi-bin/
kwhogster
Post by kwhogster »
I am trying this one also
https://exchange.nagios.org/directory/A ... or/details
Same issue
Tom
Screen shots
Screen shots
kwhogster
Post by kwhogster »
Guys,
Got it working thanks for the clues
Only have one problem now
The ICON remains Yellow can not get Green ICON all my Nagios services are GREEN
Any ideas I posted the link and screen shots in my past post maybe the author is around?
Thank you
Tom
tacolover101
Post by tacolover101 »
kwhogster wrote:Guys,
Thank you
Tom
nice one.
looks like you've got some fixing to do if you want to go green! :-)
kwhogster
Post by kwhogster »
Yes
The question is what to fix
I placed all the files in c:\program files\NTM
See attached you will see the OK ICON Critical ICON etc.
There was no install program with this one you just extracted the files from the zip file and go.
See link provided in my previous posting try it yourself
Thank you
Tom
Nagios Tray Monitor
Nagios Tray Monitor
kyang
Post by kyang »
Thanks for posting your answer! I'll be closing this topic as resolved!
If you have any more questions, feel free to create another thread!
Thank you for using the Nagios Support Forum!
