configure monitoring ping using wizard?
I'm using the Nagios XI configuration wizard and want to monitor "ping" for targeted, but I don't see this as a part of the selection from the wizard.
I see an option for "monitor a web site" so I used that option to walk through the wizard to configure the monitoring for http.
Then I use the Core Config Manager, go to services, find the http service object, make a copy, and edit and select the check command "check_ping" from the drop box and I see this in the command view "$USER1$/check_ping -H $HOSTADDRESS$ -w $ARG1$ -c $ARG2$ -p 5", but I don't know how to use the parameters and the arguements.
I'm sure how use the commands instructions should be online help, but I can't locate them.
Is there a URL that lists all commands and how to use instructions and examples?
thanks,
ik
thanks,
ik
kyang
Re: configure monitoring ping using wizard?
A pretty good place to find help is on the plugin itself through the command-line. (--help works with any Nagios plugin)
This is the output.
Another alternative is the man pages for Nagios-plugins.org
http://nagios-plugins.org/doc/man/index.html
You can also find our updated plugins on our GitHub.
https://github.com/nagios-plugins/nagios-plugins
Hope this helps.
/usr/local/nagios/libexec/check_ping --helpCode: Select all
[root@centos7x64 etc]# /usr/local/nagios/libexec/check_ping --help
check_ping v2.2.1.git (nagios-plugins 2.2.1)
Copyright (c) 1999 Ethan Galstad <[email protected]>
Copyright (c) 2000-2014 Nagios Plugin Development Team
<[email protected]>
Use ping to check connection statistics for a remote host.
Usage:
check_ping -H <host_address> -w <wrta>,<wpl>% -c <crta>,<cpl>%
[-p packets] [-t timeout] [-4|-6]
Options:
-h, --help
Print detailed help screen
-V, --version
Print version information
--extra-opts=[section][@file]
Read options from an ini file. See
https://www.nagios-plugins.org/doc/extra-opts.html
for usage and examples.
-4, --use-ipv4
Use IPv4 connection
-6, --use-ipv6
Use IPv6 connection
-H, --hostname=HOST
host to ping
-w, --warning=THRESHOLD
warning threshold pair
-c, --critical=THRESHOLD
critical threshold pair
-p, --packets=INTEGER
number of ICMP ECHO packets to send (Default: 5)
-L, --link
show HTML in the plugin output (obsoleted by urlize)
-t, --timeout=INTEGER:<timeout state>
Seconds before connection times out (default: 10)
Optional ":<timeout state>" can be a state integer (0,1,2,3) or a state STRING
THRESHOLD is <rta>,<pl>% where <rta> is the round trip average travel
time (ms) which triggers a WARNING or CRITICAL state, and <pl> is the
percentage of packet loss to trigger an alarm state.
This plugin uses the ping command to probe the specified host for packet loss
(percentage) and round trip average (milliseconds). It can produce HTML output
linking to a traceroute CGI contributed by Ian Cass. The CGI can be found in
the contrib area of the downloads section at http://www.nagios.org/
Send email to [email protected] if you have questions regarding use
of this software. To submit patches or suggest improvements, send email to
[email protected]
Hope this helps.
Thanks for the response.
However, I wish these have some examples because I'm not sure what these mean. What type of value do I use for THRESHOLD?
thanks,
ik
thanks,
ik
Not sure how to set the values..
[root@null-0800270406a2 ~]# /usr/local/nagios/libexec/check_ping -H 10.155.58.26 -w 100
<crta> was not set
check_ping: Could not parse arguments
Usage:
thanks,
ik
<crta> was not set
Usage:
thanks,
ik
kyang
percentage of packet loss to trigger an alarm state.Code: Select all
/usr/local/nagios/libexec/check_ping -H 10.155.58.26 -w 5,40% -c 10,50% -p 5
check_ping -w <rta>,<pl%> -c <rta>,<pl%>
Depends on when you want to receive alerts for warnings and criticals.
Does this help?
Yes this definitely helps - here is what I found:
This works: /usr/local/nagios/libexec/check_ping -H 10.155.58.26 -w 5,40% -c 10,50%
This doesn't work: /usr/local/nagios/libexec/check_ping -H 10.155.58.26 -w 5,40%
Error message:
<crta> was not set
Usage:
Therefore, it looks like I need the "-c 10,50%", but the instructions are not explicit, at least for me...wasn't sure what <crta> was or how to set it not until I saw your example.
Is there a way for me to run this command with all default values as if I'm just executing a ping command from any linux command line?
thanks,
ik
Error message:
<crta> was not set
Usage:
thanks,
ik
- Former Nagios Staff
Could you clarify what you mean by the above? The ping command in Linux doesn't have warnings and criticals, so I am not sure what you are going to get by just running ping.ikekim wrote: Is there a way for me to run this command with all default values as if I'm just executing a ping command from any linux command line?
Are you just wanting to be able to run check_pingfrom the command line? You'll need to put it in your path and create an alias, but that could be dangerous, as if you need to change warnings and criticals in the future you'll need to change the alias.
I'm normally configure monitoring using the Nagios XI configuration wizard.
There is no selection for me to choose just the ping configuration(there is for web URL).
When the config wizard is used to select the type of monitoring like NRPE or Web URL, I see that all the command are created with default parameters in the settings.
So, how I create the ping check so that this appears on my monitoring console display?
thanks,
ik
thanks,
ik
kyang
You can create a new ping check by going to
Home --> Configure --> Core Config Manager --> Services --> Select your host --> Add new --> Select check command for check_ping --> Pass your $ARG1$ and $ARG2$.
Dont' forget to assign the new service a template and host.
Hope this helps.
Hope this helps.
Okay, but this is brand new deployment and I have no hosts added.
Your instructions are based on if I had an existing host.
So I tried to add host using the CCM and I chose Select check command for check_ping --> Pass your $ARG1$ and $ARG2$, then when I apply the config, it gave me an error it could not apply and rolled back.
I just want to add bunch of machines and ping them....can I just add host using CCM and select the check_ping?
Not sure the difference when you should be adding a host vs. adding a service.
thanks
ik
thanks
ik
