How to update to all the hosts!!!
ponnpr7
Post by ponnpr7 »
If I have some new feature implemented how do I update to all the hosts???
dwasswa
Re: How to update to all the hosts!!!
Post by dwasswa »
Hi @ponnpr7,
It seems like you have configured an event handler. Have you looked at this dochttps://assets.nagios.com/downloads/nag ... 1493223405 ?
ponnpr7
Post by ponnpr7 »
I'm sorry if my question wasn't really clear. What I'm trying to do here I have implemented the Event Handlers for one host, how do I defined to all other sites. Is there a way can be done at once like in bulk or I have to do manually.
Ravi
kyang
Post by kyang »
There is no way to do that as of now.
You could however, run it as a global event handler. Just put the command in.
Located in --> Admin -> Manage Components -> Global Event Handlers -> Edit Settings
dwasswa
Post by dwasswa »
Thanks @yang
ponnpr7
Post by ponnpr7 »
Thanks much!!!
kyang
Post by kyang »
No problem.
Did you have any more questions, or are we okay to close this topic?
