uanble to fetch information from server
sarfarosh
Post by sarfarosh »
Hi Team,
We have configured the remote windows server in nagios server. But we are facing the subjected error. Here i will say that sometimes the output is showing and sometimes its showing this error very frequently. We have latest nagios xi and latest NSClient++ installed.
Plesase find the attached nsclient.ini and nsclient.log file for your reference.
LOG File - Client confirms that there is no firewall or proxy which is blocking nagios to connect or fetch information from windows server. Because sometimes we are getting the output and sometimes we are getting the message uanble to fetch information from server.
kyang
Re: uanble to fetch information from server
Post by kyang »
The IP address listed in the log file does not appear to be in the nsclient.ini file?
Could you add the IP address into it and restart the NSClient++ service on the remote windows server. Then see if you are able to fetch information.
Also, are you trying to use check_nt to get information? I do not see any settings for NSClient?
I'll post my nsclient.ini file so you know what I mean.
nsclientexample.ini
