LDAP / Active Directory Import
krutaw
Post by krutaw »
Just noticed something and figured I'd share. While using the LDAP/AD import component and attempting to import a fairly large group (~250 users) and the component only allows importing of 59 users at a time. To work around it (because I'm in kind of a rush) I simply split the group into groups of ~50 users but figured someone should know. Oh, latest version of Nagios XI, literally installed yesterday. :)
dwasswa
Re: LDAP / Active Directory Import
Post by dwasswa »
Hi @krutaw,
Thanks for sharing the tip. If you face any problems in the future,we are more than happy to help.
Thank you for using Nagios Support Forum and sharing your knowledge.
