We added a cisco switch to test and instead of listing the interfaces with the correct names like gi0/1 , gi0/2 , it uses some wierd namses like port1234 port 3439.
Also it does not recognize 10Gbe ports. There is also no option for Juniper equipment.
Cisco Switch
Re: Cisco Switch
Per our earlier email, can you send us the contents of the /etc/mrtg/mrtg.cfg file on the XI machine? This is the file from which port numbers are obtained. We can modify the switch wizard to use port names if we can get your config file for testing. Send the config file to [email protected]
Ethan Galstad
President
Ethan Galstad
President
