Recurring Database Connection Error
venturegardengroup
Post by venturegardengroup »
Hello Support,
I have been getting a recurring database connection error issue on my Nagios XI for over 2 weeks now. The frequency is about once in 2 days. Currently even when I run the repair command on the CLI, nothing seems to happen. How can you be of help?
See screenshot attached.
Regards,
eloyd
Cool Title Here
Re: Recurring Database Connection Error
Post by eloyd »
My immediate reaction is that almost 50,000 failed logins in as root in three days is a serious issue that needs to be addressed. Use a non-standard port, set up firewalls, activate fail2ban, and audit accounting output to make sure someone hasn't managed to guess your root password. That's pretty insane; you're averaging one failed login every six seconds, continuously.
My second reaction is to issue this command first:
Before executing:
./repair_databases.sh
Some of the XI scripts are funny and need to be run from the directory, not just called by name.
kyang
Post by kyang »
Thanks @eloyd!
@venturegardengroup, please cd into the scripts directory and then run the./repair_databasesh.sh just as eloyd mentions.
Let us know if this works or if you have any more questions.
venturegardengroup
Thanks eloyd and Kyang,
I have done exactly as requested but it is still the same issue.
@eloyd: thanks for your observation and recommendation, we are getting that fixed.
kyang
Post by kyang »
Can you tell us what version of XI you have, and run this command to tell us the database.
grep dbtype /usr/local/nagiosxi/html/config.inc.php
venturegardengroup
Hello Kyang,
I cant seem to get the version of nagios xi since I cant log into the UI. However here is the output of the command:
[root@localhost ~]# grep dbtype /usr/local/nagiosxi/html/config.inc.php
$cfg['dbtype'] = ''; // this setting is no longer used - use settings below
"dbtype" => 'mysql',
[root@localhost ~]#
dwasswa
Post by dwasswa »
Hi @venturegardengroup ,
If you cant login to the web UI please follow the steps below:
1.Open an SSH or direct console session to your Nagios XI host and execute the following command:
/usr/local/nagiosxi/scripts/reset_nagiosadmin_password.php --password=newpassword
Note: If you would like to use special characters in your password, you should escape them with "\". For example, if you want to set your new password to be "$new password#", then you can run:
/usr/local/nagiosxi/scripts/reset_nagiosadmin_password.php --password=\$new\ password\#
2.check if iptables is started, run:
service iptables status
To see if port 80 is open, run:
iptables -L -n | grep 80
You should see something like this:
ACCEPT     tcp  --  0.0.0.0/0            0.0.0.0/0           state NEW tcp dpt:80
If the port is not open, you can open it by running:
iptables -I INPUT -p tcp --dport 80 -j ACCEPT
service iptables save
venturegardengroup
Hello Dwasswa,
The issue is with the log in is DB error related rather than with the password. See output attached.
Regards,
kyang
Post by kyang »
Could you show us your mysql logs?
tail /var/log/mysqld.log
venturegardengroup
Hello Kyang,
I couldn't find any log for mysql. See the attached output for the files and directories in /var/log.
Regards,
