Nagios XI Report
nlnieme
Nagios XI Report
Post by nlnieme »
I would like to find a way to run a report that lists all HOSTS that have NOTIFICATION ENABLED set to OFF under ALERT SETTINGS. Does anyone know of a way to accomplish this?
I have attached a screen shot of the configuration I'm referring to.
Thanks.
dwasswa
Re: Nagios XI Report
Post by dwasswa »
Unfortunately, there is now way but you could submit a feature request.
This would be something easy to implement.
