hello
I am getting this error message in my log /usr/log/nagios/var
Warning: Return code of 13 for check of service 'Cpm' on host 'ukldn-ixhs-cr01' was out of bounds.
1508339580] Warning: Return code of 13 for check of service 'Network-Ports' on host 'ukfnb-acpf-cds01' was out of bounds.
[1508339580] Warning: Return code of 13 for check of service 'Lsp' on host 'ukgls-wscen-cs01' was out of bounds.
[1508339580] Warning: Return code of 13 for check of service 'Psu' on host 'ukfnb-thfb-cs01' was out of bounds.
[1508339580] Warning: Return code of 13 for check of service 'Network-Ports' on host 'ukldn-iefp-aggr6' was out of bounds.
[1508339580] Warning: Return code of 13 for check of service 'Fans' on host 'ukman-tcwh-sc01' was out of bounds.
[1508339580] Warning: Return code of 13 for check of service 'Lsp' on host 'ukfnb-acpf-vsg03a' was out of bounds.
[1508339581] Warning: Return code of 13 for check of service 'Psu' on host 'ukfnb-acpf-vsg02a' was out of bounds.
[1508339581] Warning: Return code of 13 for check of service 'Temperature' on host 'ukfnb-acpf-vsg04b' was out of bounds.
[1508339581] Warning: Return code of 13 for check of service 'Network-Ports' on host 'ukmds-ndmai-cs01' was out of bounds.
[1508339581] Warning: Return code of 13 for check of service 'radius-1812' on host 'rad1-erx.exponential-e.net' was out of bounds.
[1508339581] Warning: Return code of 13 for check of service 'Fans' on host 'ukfnb-acpf-vsa02' was out of bounds.
bolson
Re: Warning: Return code of 13 for check of service 'Cpm' on
Are these nrpe checks? Are the hosts being checked Windows or Linux? This error is usually a permissions issue. Can the checks be performed successfully from the command line?
yes it is a permission issue on the actual file in the /usr/local/Nagios/libexec
Please close the case
kyang
Sounds great! I'll be closing this topic!
If you have any more questions, feel free to create another thread!
Thank you for using the Nagios Support Forum!
