Acknowledgements in Operations Screen
eltrasimaco
Post by eltrasimaco »
Hi, I' would like to show acknowledge states in operation screen along with the rest of hosts/service problems, although I read somewhere nagios team think it doesnt make sense to display them here. Nevertheless, I would be grateful if being directed to some other solution than going to Home->Acknowledgements.
kyang
Re: Acknowledgements in Operations Screen
Post by kyang »
So you want another way to view acknowledgments?
How about XI Home --> under "Quick View" --> click Tactical Overview --> Then you should see something like "10 acknowledged".
This will show the acknowledged hosts or services that are specific to warnings or critical.
Otherwise, I don't see another way to view them other than Home --> Acknowledgements.
Is there a reason for wanting a different display?
eltrasimaco
Thanks for your reply; really, what i was looking for, is the operations center screen, "as is", but including acknowledged services(hosts
tacolover101
Post by tacolover101 »
this would be a great feature request. i think there might be one out there for it too somewhere.
"allow custom fields for operations screen" - it's got a great ring to it. :)
npolovenko
Post by npolovenko »
Thanks, @tacolover101!
I will go ahead and put a feature request for this.
