Socket Timeout after 10 Seconds
amitgupta19
I added a new server to the Monitoring and immediately it started giving the following Error:
CRITICAL - Socket timeout after 10 seconds
Currently i am monitoring the following services: CPU Load, C Drive, Up Time and memory usage and all the services are giving the same Error.
Please suggest How to correct it?
- Former Nagios Staff
Re: Socket Timeout after 10 Seconds
Are you using NRPE? If so, please take a look at https://support.nagios.com/kb/article/n ... conds.html
Also, please post the nrpe.cfg from the remote machine as an attachment (and /etc/xinetd.d/nrpe, if you have it). Also, please post the output from the remote server of ps -aef | grep nrpe in a code block.
amitgupta19
Remote Host is a Windows Server.
I am using the NSClient to fetch the data from the remote host.
dwasswa
Hi @ amitgupta19 ,
Please go to your windows host and open the nsclient.ini file.
In that file go to the line and make sure your nagios ip is included. if not, please do include it.
After making those changes,please restart the NSClient service on your windows machine. Please make sure its running.
Also,go to your firewall on nagios server and make sure that port 12489 is open.
Here is also a guide on configuring NSClient...https://assets.nagios.com/downloads/nag ... 1493223405
Please confirm those and give me an update.
allowed hosts = 127.0.0.1,::1,<your nagios ip goes here>After making those changes,please restart the NSClient service on your windows machine. Please make sure its running.
amitgupta19
I have checked and made the suggested changes.
But still same error.
Please suggest.
Please suggest.
dwasswa
Hi @amitgupta19,
Please post how you defined your check command for those services. For example:
check_nt!xxx xxx xxxx or check_nrpe!xxx xxx xxxx
Where is your check command defined? Please send me the file.
It may be located at /usr/local/nagios/etc/objects/commands.cfg on your system, but you will need to locate it if your system is set up differently.
I would also like to see how your services are defined, so please send me the config file in which you have them defined.
Lastly, please attach your nsclient.ini file from your windows machine; I would like to check a few configurations.
amitgupta19
I have attached all the Files
Please have a look.
It should be helpful for you.
Please have a look.
checkcommands.cfg- (25.87 KiB) Downloaded 781 times
nsclient.ini- (322 Bytes) Downloaded 682 times
services.cfg- (87.8 KiB) Downloaded 619 times
dwasswa
Hi @ amitgupta19,
After looking into your checkcommands.cfg file, i noticed that you have your check_nt command defined wrong.
You need to specify port 12489 among the arguments with -p 12489. This is the port through which Nagios communicates with NSClient on windows.
That is why you are getting the
Please see example for ideal check_nt command:
For more information about the check_nt command, please follow this link...check_nt_command
Please make the changes stated above, restart Nagios and let me know if that solves your issue.
socket time outCode: Select all
command_name check_nt
command_line $USER1$/check_nt -H $HOSTADDRESS$ -p 12489 -v $ARG1$ $ARG2$
dwasswa
Secondly, after looking into your nsclient.ini file, I strongly suggest that you reinstall the NSClient agent. It did not have any configurations.
Please follow this kb article for information on installing NSCLient...Installing-The-Windows-Agent-NSClient
Please follow this kb article for information on configuring NSCLient...Configuring-The-Windows-Agent-NSClient
amitgupta19
@dwasswa
I changed the port option only for the CPU Load as suggested by you. But not working. Screenshot attached for your referrence.
I went through the link for the check_nt command.
It says that Port is optional.
Also all other servers are being monitored without any error, how come this is the only server requires the port to be specified.
Please suggest.
Please suggest.
- Port Option.PNG (10.77 KiB) Viewed 14398 times
