The nagios graph is not displaying for all servers and services which are monitored with this tool.
To resolve this issue, I normally just restart the npcd service, and the graphs get generated again.
However, this time, even after restarting, the problem is still the same. These are the commands that I have used to restart the npcd service :
# /usr/local/pnp4nagios/bin/npcd -d -f /usr/local/pnp4nagios/etc/npcd.cfg >>>>>This did not work
>>>> These did not work
# service nagios stop
# service nagios start
# service npcd stop
# service npcd start
#service npcd restart >>>>>Also did not work
How do I resolve this problem?
Graph not displaying
Re: Graph not displaying
Can you share your npcd and perfdata logs? Unfortunately I cannot tell you where to find them as I do not know how NPCD or PNP4Nagios was setup on your machine. They're typically called perfdata.log and npcd.log. If you can share the documentation you use, that would be helpful.
- Former Nagios Staff
Thanks @mcapra
Assuming you have the default file names, the following should help you locate the file path: find / -name npcd.log
