Ruby require 'gem' issues
bellrd07
Post by bellrd07 »
When I write a check in Ruby and must require or load a gem the require statement returns true or false which causes nagios to ignore the rest of the script. Is there a way to get around this as it is causing nagios to exit with warning status and not read any of the actual output?
Any tips would be appreciated.
Re: Ruby require 'gem' issues
Post by dwhitfield »
I'm not sure how you would execute this in your instance, but it is possible to write ruby plugins without require or load statements, such as the one below:
#!/usr/bin/ruby
# Written by Florian Seidel
# v 0.2
# Get Error Level, 255 is good
#First Command-Line Argument should be the IP of the IMM
IMM_IP = ARGV[0]
SNMPv1_community = ARGV[1]
# Getting Error Level
# 255 = Normal, 0 = Critical, 2 = Non-critical Error, 4 = System-level Error
error_level=`snmpget -v 1 -c #{SNMPv1_community} #{IMM_IP} .1.3.6.1.4.1.2.3.51.3.1.4.1.0 -O q -O v`
#What is the Problem?!
case error_level.chomp.to_i
when 255
	puts "WLC Hardware Status: OK"
	puts `snmpwalk -v1 -c #{SNMPv1_community} #{IMM_IP} .1.3.6.1.4.1.2.3.51.3.1.4.2.1.3 -O q -O v`
	exit 0
when 0
 	puts "WLC Hardware Status: Critical"
	exit 2
when 2
 	puts "WLC Hardware Status: Warning"
	exit 1
when 4
 	puts "WLC Hardware Status: "
	exit 2
else
 	puts "Unknown"
	exit 3
end
bellrd07
Post by bellrd07 »
I am requiring the mysql2 gem. How would I run the script without requiring that gem? This is my simplified code. However, Nagios gets the return value from require 'mysql2' and ignores the rest of the output.
#!/usr/bin/env ruby
    require 'mysql2'
    client = Mysql2::Client.new(:host => "host", :username => "dbuser", :password => 'dbpw', :database => 'db')
    items = client.query('SELECT vj.jobid, vj.accno, vj.fee, count(vd.docid), sum(vd.pages)
        FROM vpo_jobs AS vj
        left join vpo_documents AS vd ON (vd.jobid = vj.jobid)
        WHERE vj.datesubmitted >= "2017-10-17" AND vj.datesubmitted < "2017-10-18"
        GROUP BY vj.accno')
    results = Array.new
    graph = Array.new
    items.each do |h|
       results.push("#{h['accno'].upcase} Fee:#{h['fee']} Envelopes:#{h['count(vd.docid)']} Pages:#{h['sum(vd.pages)']}")
       graph.push("#{h['accno'].upcase} envelopes = #{h['count(vd.docid)']} #{h['accno'].upcase} pages = #{h['sum(vd.pages)']}")
    end
    graph = graph.join(" ").strip
    results = results.join("; ").strip
    puts "#{results} | #{graph}"
    exit 0
Post by mcapra »
Here's a very popular AWS plugin written in Ruby:
https://exchange.nagios.org/directory/P ... us/details
Glancing at the source, you may notice that the actual execution of things exists in a begin end block:
begin
  opts = {
    :removes => [ "Amazon", "AWS", "(Ireland)" ],
    :services => [ "Elastic Compute Cloud", "Simple Storage Service" ],
    :region => "EU_block",
  check = Nagios::AWS::DashboardCheck.new(opts)
  exit check.run()
rescue => e
  warn e.message
  warn e.backtrace.join("\n")
  exit Nagios::EXIT_UNKNOWN
end
You might try something like that.
Thanks @mcapra! OP, did you have any additional questions?
