On my Nagios XI installation I have received errors from 3 hosts during the last 3-4 days.
The same service checks have been working fine until now.
The same errors appear on all hosts:
- ERROR: Description/Type table : No response from remote host 'x.x.x.x'
(check_xi_service_snmp_linux_storage) several disks
- No answer from host
(check_xi_service_snmp_linux_load) cpu load
- ERROR: Alarm signal (Nagios time-out)
(check_xi_service_snmp_linux_process) different processes
On one of the hosts some other service checks are working fine.
I'm not able to do a snmpwalk to either of the 3 hosts.
Nmap shows filtered snmp.
I have compared to other similar hosts, but I'm not able to see any differences.
Any suggestions what the problem might be?
CentOS 6.9 64-bit
Nagios XI 5.4.10
problem with check_snmp on linux
kyang
Re: problem with check_snmp on linux
Can you show us the output of the snmpwalk command you are running? Or is there no output?
Is it something like this?
Is the service snmpd started on the 3 hosts? What is the OS of the other three hosts?
snmpwalk 192.168.4.125 -c StrOngCOmmunity -v2c
