Configuring e-Mail Notifications in Nagios Core
at the moment I use Nagios version 4.3.2 by SMS notification but I would also like to use Nagios by mail notification if a server ot host is down. I have search alot but it seems to be old stuff. Do you have any idea how I should configure that. I have looked at this example:
http://www.telnetport25.com/2012/02/con ... gios-core/
but it is from February 2012. If I should use this example I'm afraid opening up “Anonymous Users” on my Exchange server2010. Do you have any idea how I could solve this issue ?
Michael Pierre
Forenede Gruppeliv
2500 Valby
Copenhagen
Forenede Gruppeliv
2500 Valby
Copenhagen
dwasswa
Re: Configuring e-Mail Notifications in Nagios Core
Hi @ michaelpn
Do you already have your exchange server configured to accept emails from the Nagios Server?
Also, what Linux distribution and version are you running?
Please go to /usr/local/nagios/etc/objects and send me contacts.cfg and commands.cfg files.
Example of contents in contacts.cfg:
Example of contents in commands.cfg:
I am asking for those files because I want to see how you have your contacts and commands are to send SMS notifications
define contact{
contact_name nagiosadmin ; Short name of user
use genericcontact ; Inherit default values
alias Nagios Admin ; Full name of user
email your_email ; <<***** CHANGE THIS TO YOUR EMAIL
command_name notify-host-by-email
command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /bin/mail -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
Hi dwasswa,
I have already configured my Exchange Server to accept emails from Nagios Server.
My Linux Version is Ubuntu 14.04,05 LTS
Attached contacts.cfg and commands.cfg
I have tried your example today but not succeeded ;(
contacts.cfg- (3.45 KiB) Downloaded 4549 times
commands.cfg- (8.11 KiB) Downloaded 4261 times
Michael Pierre
Forenede Gruppeliv
2500 Valby
Copenhagen
Forenede Gruppeliv
2500 Valby
Copenhagen
dwasswa
Hi @ michaelpn,
Looking at your contacts.cfg file, you need to make some modifications to get email notifications.
In your contacts.cfg file, add the following lines to your contact definitions:
Next to your host_notification_commands directive, add host-notify-by-email, these are delimited by a comma.
You must also add a directive called email to your contact definitions with your email address.
See example below:
After making changes to contacts.cfg file, save and close it then restart Nagios with the following command...sudo service nagios restart
For more information about Nagios and object definitions, take a look at this guide...https://assets.nagios.com/downloads/nag ... ml#contact
Please make the changes above and let me know if you have any questions.
See example below:
define contact{
contact_name mnl ;Short name of user
use generic-contact ;Inherit default values from generic-contact template (defined above)
alias Martin Noergaard ;Full name of user
pager 0045xxxxxxxx
email <your email goes here>
host_notification_period 24x7
host_notification_options d,u,r
host_notification_commands notify-host-by-sms,host-notify-by-email
}After making changes to contacts.cfg file, save and close it then restart Nagios with the following command...sudo service nagios restart
Hi dwasswa,
Now I have done what you have asked for. I do not get any failure. I'm being notified from my sms gateway but I do not get any message like email from Nagios. I took a view at log:
Notification[11-01-2017 13:25:24] HOST NOTIFICATION: mpn;W2012_Tmp;DOWN;notify-host-by-sms;CRITICAL - Host Unreachable (172.31.1.82)
Host Notification[11-01-2017 13:25:24] HOST NOTIFICATION: mpn;W2012_Tmp;DOWN;notify-host-by-email;CRITICAL - Host Unreachable (172.31.1.82)
By restarting services from Nagios is okay done, done
so why do I not get an email ? I have my own private email too - nothing
Do I have to install anything extra as I wrote to you some are installing Postfix but that seems like overkill ?
Michael Pierre
Forenede Gruppeliv
2500 Valby
Copenhagen
Forenede Gruppeliv
2500 Valby
Copenhagen
dwasswa
Hi @michaelpn
Yes, there has to be a mailer daemon installed on the server for Nagios to use to send email from to their Exchange server.
Postfix can be used orSendmail can be used. Therefore, you need to install one of them and set it up to relay to their exchange server.
Here is an article on how to set up postfix for relaying emails to another email server...https://www.howtoforge.com/postfix_rela ... mailserver
Please implement the steps above and let me know if that resolves your issue.
Hi dwasswa,
by Configuring Postfix For Relaying the link you sent me : https://www.howtoforge.com/postfix_rela ... mailserver - do I have to configure for every person who I would like to sent a mail ? In my contact.cfg list I have as you know 6 persons who are notified by Host from SMS Gateway if I want them to be notified by mail (My Postfix is Configured) do I have them all using this command: echo "smtp.example.com someuser:howtoforge" > /etc/postfix/sasl_passwd which be like this;
echo "mail.fg.dk mpn:12345678" /etc/postfix/sasl_passwd - and for my colleges? Do I have to run the hole setup from beginnig to end by every user ?
Michael Pierre
Forenede Gruppeliv
2500 Valby
Copenhagen
Forenede Gruppeliv
2500 Valby
Copenhagen
- Former Nagios Staff
You're probably just going to be sending email as one user, correct? That would be the only user that needs to auth.
Hi dwhitfield ,
As I wrote you to mdays ago I have installed postfix and Configure Postfix For Relaying
I did configure the rest and i'm able to send an Test mail with this command:
guser@Nagios:~$ echo "Subject: sendmail test" | sendmail -v [email protected]
Mail Delivery Status Report will be mailed to <nguser>.
and I get this from maillog:
Reporting-MTA: dns; Nagios
X-Postfix-Queue-ID: 2D1B7560744
X-Postfix-Sender: rfc822; [email protected]
Arrival-Date: Tue, 7 Nov 2017 15:07:50 +0100 (CET)
Final-Recipient: rfc822; [email protected]
Action: relayed
Status: 2.6.0
Remote-MTA: dns; fgmail3.fg.dk
Diagnostic-Code: smtp; 250 2.6.0 <20171107140750.2D1B7560744@Nagios>
[InternalId=128207] Queued mail for delivery
--2D1B7560744.1510063671/Nagios
Content-Description: Message Headers
Content-Type: text/rfc822-headers
Return-Path: <[email protected]>
Received: by Nagios (Postfix, from userid 1000)
id 2D1B7560744; Tue, 7 Nov 2017 15:07:50 +0100 (CET)
Message-Id: <20171107140750.2D1B7560744@Nagios>
But if I try to use the host_notification_commands notify-host-by-sms,notify-host-by-email - I get this message:
[1510139816] HOST NOTIFICATION: mpn;W2012_Tmp;DOWN;notify-host-by-email;CRITICAL - Host Unreachable (172.xx.x.xx)
[1510139816] HOST NOTIFICATION: mpn;W2012_Tmp;DOWN;notify-host-by-sms;CRITICAL - Host Unreachable (172.xx.x.xx)
[1510139816] wproc: NOTIFY job 219 from worker Core Worker 19936 is a non-check helper but exited with return code 127
[1510139816] wproc: host=W2012_Tmp; service=(none); contact=mpn
[1510139816] wproc: early_timeout=0; exited_ok=1; wait_status=32512; error_code=0
[1510081046] wproc: stderr line 01: /bin/sh: 1: usr/bin/mail: not found
[1510081046] wproc: stderr line 02: /usr/bin/printf: skrivefejl: write error: Broken pipe
What do I have to do ? I'm almost there now
I have tried allot to solve the issue but I did not find the problem
Should I also install mailx ?
You still have the files I guess ?
Action: relayed
Status: 2.6.0
Michael Pierre
Forenede Gruppeliv
2500 Valby
Copenhagen
Forenede Gruppeliv
2500 Valby
Copenhagen
kyang
Do you still receive SMS notifications?
Run this commands and tell us the output.
which mailCode: Select all
/usr/bin/mail
quit
