Hi Team,
We are using nagios XI ver. 5.4.8
Please help with below points.
1 - Duration of RAW data retained by nagios xi. if its gets purge help us with how & where it gets purge.
2 - Duration of logs retention period.
3 - Alerts data retention period.
Rohan
Data retaintion duration
Re: Data retaintion duration
Hi Team,
Need your help on this.
Regards,
Rohan
Regards,
Rohan
npolovenko
- Support Tech
Hello, @lrnnetops.
1. Nagios XI stores RAW performance data in Round Robin Database. It automatically shrinks and averages out the older performance data, optimizing the storage consumption. There is no available/reliable GUI option to change the historical data retention period as of right now, however, if you take a look at this file:
You will see:
So Nagios will store performance data for 4 years. But again, it should not consume huge amounts of storage because of the optimization process.
If you'd like to delete RRD files you can check this direcotry:
2. You could check and modify log retention times in /usr/local/nagiosxi/html/config.inc.php You could also run ls -l command in key nagios log directories and delete logs older than X date. Here's the link to learn more about log locations https://assets.nagios.com/downloads/nag ... gIGjfD_BwE
3. Alerts would be stored in nagios.log file. By default, each day Nagios archives that file and puts the old ones in
You could modify that setting in /usr/local/nagios/etc/nagios.cfg:
# n = None - don't rotate the log
# h = Hourly rotation (top of the hour)
# d = Daily rotation (midnight every day)
# w = Weekly rotation (midnight on Saturday evening)
# m = Monthly rotation (midnight last day of month)
Did that answer your questions?
nano /usr/local/nagios/etc/pnp/rra.cfgCode: Select all
RRA:AVERAGE:0.5:30:4320
# 5840 entries with 360 minute step = 4 years
RRA:AVERAGE:0.5:360:5840If you'd like to delete RRD files you can check this direcotry:
/usr/local/nagios/share/perfdata3. Alerts would be stored in nagios.log file. By default, each day Nagios archives that file and puts the old ones in
/usr/local/nagios/var/archivesCode: Select all
log_rotation_method=d# h = Hourly rotation (top of the hour)
