Nagios XI suddenly stopped working - repaired db... no luck!
dbsaust
Post by dbsaust »
We can't access Nagios XI system. Login page prompted the following. repair_databases.sh executed couple of times. No luck! Kindly assist.
Message: A database connection error has been detected, we are attempting to repair the server, if the repair does not resolve the issue, please contact Nagios support.
Run the following from the CLI as root to attempt to repair the DB
/usr/local/nagiosxi/scripts/repair_databases.sh
kyang
Re: Nagios XI suddenly stopped working - repaired db... no l
Post by kyang »
Which version of XI are you on and what OS?
Is your database running? Run this command to show us which db.
awk '/"nagiosxi" => array\(/{getline;print}' /usr/local/nagiosxi/html/config.inc.php
Can you show us your db logs?
tail -50 /var/log/mysqld.log
Or if you have mariadb
tail -50 /var/log/mariadb.log
dwasswa
Post by dwasswa »
Hi @dbsaust ,
Please run the following commands and post the output:
MySQL
tail -n 20 /var/log/mysqld.log
MariaDB
tail -n 20 /var/log/mariadb/mariadb.log
Please send me your system profile by following the steps below:
Go to Admin >> System Profile
Then click Download Profile and send it.
dbsaust
Post by dbsaust »
Hi @dwasswa and @kwang,
Thanks for your replies.
You guys are right. We checked the log and found disc space issue, as below. This is now resolved.
170919 19:49:23 [ERROR] /usr/libexec/mysqld: Error writing file '/var/run/mysqld/mysqld.pid' (Errcode: 28)
170919 19:49:23 [ERROR] Can't start server: can't create PID file: No space left on device
Thanks again.
kyang
Post by kyang »
Sounds great! I'll be closing this topic as resolved!
If you have any more questions, feel free to create another thread!
Thank you for using the Nagios Support Forum!
