Host/service notification emails not working
GldRush98
Post by GldRush98 »
Send test emails: work
Account creation emails: work
Sending at shell as nagios user: work
Host/service notification emails: NOT WORKING
This is a brand new vmware image of 5.4.10 (upgraded to 5.4.11) centos6. Email notifications are not sending out of the system.
nagios.log shows notifications being issued:
[1510070982] SERVICE ALERT: GCC-DC01;Print Spooler TEST;OK;HARD;2;Spooler: Started
[1510070982] SERVICE NOTIFICATION: nicktest;GCC-DC01;Print Spooler TEST;OK;xi_service_notification_handler;Spooler: Started
[1510071639] SERVICE ALERT: GCC-DC01;Print Spooler TEST;CRITICAL;SOFT;1;Spooler: Stopped
[1510071649] SERVICE ALERT: GCC-DC01;Print Spooler TEST;CRITICAL;HARD;2;Spooler: Stopped
[1510071649] SERVICE NOTIFICATION: nicktest;GCC-DC01;Print Spooler TEST;CRITICAL;xi_service_notification_handler;Spooler: Stopped
But the debug log shows them never hitting the system to actually send out. I see the tests and the account creation messages though! phpmailer.log:
[11-07-2017 10:04:54] Message sent! (method=sendmail), Referer: admin/testemail.php
[11-07-2017 10:08:51] Message sent! (method=sendmail), Referer: admin/users.php > Account Creation
[11-07-2017 10:28:39] Message sent! (method=sendmail), Referer: account/testnotification.php > PHPmailer Test
I even tried changing the email method from Sendmail to SMTP... exact same thing happens. Tests work, notifications don't.
I've checked postfix settings compared to a working system, and no remarkable differences.
I've been up and down all the settings and I can't find anything I'm missing. I've set up many XI systems before and have never ran in to a problem like this. I keep thinking there is something obvious, but like I said, I've been up and down the settings and don't know what else to troubleshoot at this point. Help :(
Prod XI: Debian 12 - Nagios XI 2026R1.2
Dev XI: Debian 12 - Nagios XI 2026R1.2
npolovenko
Re: Host/service notification emails not working
Post by npolovenko »
@GldRush98, let's make sure that all the right settings are enabled first.
Click on the username in top right corner of the web interface. Then notification methods in the left column and make sure that Receive alerts via emailoption is enabled. Also, click on notification preferences and make sure that notifications are enabled there as well. Check what types of alerts you'd like to receive as well and click on update settings.
Here's the reference: https://assets.nagios.com/downloads/nag ... ios-XI.pdf
GldRush98
Post by GldRush98 »
Been there, done that. Looked at those pages a dozen times already...
dwasswa
Post by dwasswa »
Hi @ GldRush98,
Please run the following command...tail -f /usr/local/nagiosxi/var/eventman.log
This command can be used to watch the logs related to events and notifications in Nagios XI.
As you run that command, force an immediate check by clicking on service that is in an Warning or Critical state, then watch the logs and post the output.
See steps below:
Step 1: Establish terminal session and run command
Step 2: Go to Service Detail menu and click on a Warning or Critical service.
Step 3: On the Service Status Detail page for that service, click on Force an immediate check to the right under the Quick Actions options.
Step 4: Watch the logs for at least 30 seconds and then post the output.
GldRush98
Post by GldRush98 »
Ok, I forced an immediate check and waited... PROCESSED 0 EVENTS
I changed the state of the service from Critical -> Good and forced a check and waited. PROCESSED 0 EVENTS
I don't see anything other than 0 events through this time. It's been several minutes... Problem?
[nagios@nagios root]$ tail -f /usr/local/nagiosxi/var/eventman.log
PROCESSED 0 EVENTS
PROCESSED 0 EVENTS
PROCESSED 0 EVENTS
PROCESSED 0 EVENTS
PROCESSED 0 EVENTS
PROCESSED 0 EVENTS
PROCESSED 0 EVENTS
PROCESSED 0 EVENTS
GldRush98
Post by GldRush98 »
::rubseyes:: The forum has changed before my very eyes :shock:
Can you run the following as root and post the /tmp/info.txt file?
echo 'select * from xi_events;' |mysql -t -u root -pnagiosxi nagiosxi >/tmp/info.txt
echo 'select * from xi_eventqueue;' |mysql -t -u root -pnagiosxi nagiosxi >>/tmp/info.txt
echo 'desc xi_events;' |mysql -t -u root -pnagiosxi nagiosxi >>/tmp/info.txt
echo 'desc xi_eventqueue;' |mysql -t -u root -pnagiosxi nagiosxi >>/tmp/info.txt
ps -ef --cols=300 >>/tmp/info.txt
tail -50 /usr/local/nagiosxi/tmp/phpmailer.log  >>/tmp/info.txt
Just want to check to see if the MYSQL tables are setup correctly and that there is not any corrupted data causing them to not send.
Also, go to the Admin > Monitoring Engine Status menu and make sure notifications are enabled in the Monitoring Engine Process dashlet.
GldRush98
Post by GldRush98 »
The first 2 select queries were empty (nothing returned).
Notifications are enabled from monitoring engine status.
Info txt file attached.
Thanks for the file. Everything looks good in it.
Can you upload a or PM me your System Profile as well as the following log files?
/usr/local/nagiosxi/var/event_handler.log
To post your system profile. Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and upload it to the post or PM it to me.
GldRush98
Post by GldRush98 »
Ok, PM sent. This was a vmware image from the Nagios site from a couple weeks ago, and it's had almost nothing done on it but some basic set up, so not sure what happened.
